tiuvlad
Prepare file for printing
Nov 3, 2013 3:35 AM
Tags: #print #cs6 #curves
I've been using Ps for quite a while now, but recently I had to expand my work to Illustrator as well. I am pretty much a newb when it comes to it though, and recently I had to send some logos to a printing company, in order for them to laser-print the logos on some pens. They replied back to me, saying that the logos needed to be "broken into curves" before they could go ahead and print them.
I have no idea what that means, and I've been on Google since early this morning, looking for an answer.
Can anyone help?
    Nov 3, 2013 3:47 AM   in reply to tiuvlad
    Depends upon:
    • Exactly what you mean by "laser print." That could be anything from ordinary toner-based laser printing on a paper insert or transfer, to laser engraving.
    • The nature of the artwork. Show a screenshot of it.
    You always need at least a fundamental understanding of the process involved in the printing method for which you are designing. That's why logo design is not a simple matter of making something "look good" on your monitor and then sending it to the broad array of service providers in different industries who are supposed to render it using various media technologies. Different kinds of output require different kinds of input.
    JET
    Nov 3, 2013 4:39 AM   in reply to tiuvlad
    The grads are likely to be problematic. The printing method may be foil-based, transfer-based, or screen printing, which often require line art (artwork free of halftone dots), especially at small reduction sizes. That's one reason why it is commonly best to avoid contone artwork (grads, blends, raster-based tones) in proper logos.
    And it's one possible reason why the imprinter insists on its being "broken into curves" (a very poorly stated requirement). He probably means having all the elements provided as closed paths so he can apply solid fills. (Text converted to paths; nothing in the clover leaf being dependent upon overlapping objects, for example if the white in the clover leaf is actually done by separate white-filled paths.)
    Generally speaking, you don't want an output house having to modify your files. You should consider it your responsibility to deliver files suitable for the intended repro method. It is quite common that the technicians working at an output house may be experts in their particular media, but know next to nothing about preparation of the artwork files (as is suggested by the poorly-stated requirement).
    That's why "as far as I know" doesn't cut it. An office copier is a "laser printer." But obviously, you can't run a writing pen through an office copier to have it imprinted.
    There are, however, many writing pen models commonly used in imprinted specialty marketing which involve a paper insert behind a clear pen barrel. The imprint is just printed on paper, and can be printed with ordinary "laser printing" devices.
    At the other end of the spectrum, it is also quite common in imprinted specialty marketing to employ what is technically a laser engraver which actually uses a laser beam to etch a design into a metal pen barrel, or to expose a light-fixed coating.
    If there is one, provide a web link to the specific vendor and the specific pen model you are trying to design for.
    JET
    Nov 3, 2013 5:05 AM   in reply to tiuvlad
    I I were to keep the gradient, what would be the best way to do that?
    If the repro method requires line art, the grads have to go, by definition of line art. That's just the way it is.
    My frustration here comes from not knowing WHAT I should do...
    The frustration of anyone trying to help you--on Sunday when the printing sales rep is unavailable, and his website is down--comes from simply not having the information required to advise you.
    ...once I would know that, tutorials and the good old "trial and error" should help me get the job done....
    You don't want to even get me started on that. Completely amateurish, fumbling-about way to work. You have to know what you're doing. It's not rocket science, but would you want someone working on your house wiring who has a "good old trial-and-error and tutorials" attitude about his work?
    JET
