> I am actually using SMF...I can use PHP if it would help
This?
http://www.simplemachines.org/
That's a forum written in php/mysql
So it's running on the site, then you can use php on regular
php pages.
What you need to is make an html page with the form, and set
the form's
action to point to a form handling script on the server.
canned reply #12 dash 493
What does the hosting's FAQ/support pages say about form to
email scripts?
Is there a hosting control panel or CPanel? If yes- look in
there.
If you can use PHP scripting, here's a quick list of
instructions for a
particular script:
Refer to the docs folder in the expanded zip file for more
info.
1)go to
http://boaddrink.com
-->phpformmail
download it.
extract the ZIP file.
2) open formmail.php in dreamweaver
Make the following changes (in code view, turn line numbers
on)
2a)
line 4,
define('CHECK_REFERER', true);
change to:
define('CHECK_REFERER', false);
reason: too many people use a firewall or Norton security to
restrict this.
2b)
Line 43
$referers = array('www.example.com', 'example.com');
change to the url address of your web site.
reason: this probably isn't needed since we just turned the
referrer
checking off. but change it anyway.
2c) *this is to hard-code the recipient address into
the php
file, where it is totally invisible *
Line 46
$recipient_array = array();
change to:
$recipient_array = array('me' =>
'youremailaddr...@example.com);
**of course, replace youremailaddr...@example.com with
the email address
you want to receive the form data
reason: this sets the email address the form results will be
sent to.
2d) give the script a default "From" address to use.
Go to line 41
Change:
define('FROM', null);
to:
define('FROM', 'Example Name <e...@example.com>');
substituting your name and email address.
3) now do a File-->Save As and save this file to within
this Local Site
folder. save it as anythingyouwant.php
4) in dw's File Panel, find anythingyouwant.php and upload it
to the remote
site.
5) Now open your form html file in dreamweaver,
5a)click the mouse into the form area, and select the
<form> tag on the
lower left margin of the design window.
In the Property Inspector, it should now show the properties
of the <form>
tag. In the Property Inspector, to the right of the ACTION
line, click the
folder icon and browse to and select the anythingyouwant.php
file
you've saved to within this site.
5b) now go to dw menu-->Insert-->Form
Objects-->Hidden Field
This inserts a hidden form field.
In the property inspector, change the NAME/ID of this field
to: recipient
And the VALUE of this field to: me
the code should look like:
<input name="recipient" type="hidden" id="recipient"
value="me">
This tells the script to use the "me" recipient_alias value
as the email
address to send the form to.
5c: Do you have a form field to collect the user's email
address?
If yes, if this field is named exactly "email" then the
script will use the
user's email as the reply to in the outgoing email
6) Save and upload the form page.
Try the form from the website.
Optional:
1-make a new page for a thank you for submitting message.
In the form, insert another hidden field.
Value: the full absolute
http:// address to the new thank you page.
If you don't set a redirect value- the form script will build
a "thank you,
here is what you submitted" page. If you want to use that
dynamic page-
upload the .css file that it uses.
2- If you have a field in the form to collect the visitor's
email address,
IF you name this field in the form exactly
email then the visitor's
email address will be the Reply To address in the outgoing
email.
There are 30 or so other optional form fields to control the
form- see the
readme in the docs folder. One of those optional control
fields is
verification.
Alan
Adobe Community Expert, dreamweaver
http://www.adobe.com/communities/experts/
