Strom37
Renaming Tag Attribute
Nov 3, 2013 6:14 AM
Tags: #dreamweaver_cs6 #tag_attributes
Cannot rename an "a" tag attribute in a DWT. I go to Modify, Templates, Make Attribute Editable. In the pop up I click add, another pop_up box asks me to name the new attribute. However it will not let me type anyting in the naming box.
Any assitance is appreciated.
    Nov 3, 2013 8:43 AM   in reply to Strom37
    2 step procedure.
    First, define the editable attribute in the main template.dwt file.  In this example, I'm making the class attribute editable on my <body> tag.
    Next, open a child page based on your Template.  Go to Modify > Template Properties.
    Is that what you're doing?
    Nancy O.
    Nov 3, 2013 9:05 AM   in reply to Strom37
    I don't really need a lesson on all this .  It's works fine for me.
    Can you tell us which version & build # of DW you're using?
    Also, elaborate a bit on what isn't working for you and in which screen shots?
    Nancy O.
    Nov 3, 2013 9:38 AM   in reply to Strom37
    Does your Template.dwt contain any class attributes in the code like this?
    <ul>
    <li><a class="home" href="home.html"></a></li>
    <li><a class="about" href="about.html"></a></li>
    <li><a class="contact" href="contact.html"></a></li>
    </ul>
    Nancy O.
    Nov 3, 2013 9:53 AM   in reply to Strom37
    After you make the class attribute editable -- in this example "home," your code should look like this:
    <li><a href="home.html" class="@@(home)@@"></a></li>
    I've tested it both ways -- with and without classes in the code.  It works for me on Win with CS6 12.2 build 6006.
    Nancy O.
    Nov 3, 2013 11:54 AM   in reply to Strom37
    I can't reproduce your problem at my end.  When things don't work the way they should, it's sometimes a bad Cache or Personal Configuration file.
    See Deleting Corrupted Cache in DW
    http://forums.adobe.com/thread/494811
    Nancy O.
