Momo13
Farbraum in Lightroom 5
Nov 3, 2013 8:21 AM
Tags: #farbraum #lightroom5
Ich habe von Lightroom 3 auf 5 upgedatet. Seit dem sind mir Farbunterschiede zwischen Entwickeln und Biliothek bei Bildern mit großem Farbumfang aufgefallen. Welche Farbräume werden in den beiden Modi verwendet?
    Nov 3, 2013 9:46 AM   in reply to Momo13
    Develop uses linear ProPhoto (ProPhoto primaries, but gamma 1.0). Library uses Adobe RGB jpegs.
    If you can see any difference between them, that's normally an indication of a problem with the monitor profile.
    A wide gamut monitor does extend very slightly beyond Adobe RGB in some colors, and so could be able to show a small difference in gamut between those two. But it would be more theoretical than practical. I'd go after the monitor profile as prime suspect.
    With a standard gamut monitor, there's no way you should see any difference.
    Nov 4, 2013 11:44 AM   in reply to Momo13
    Momo13 wrote:
    The Monitor (ASUS P246q) is a wide gamut display and I use the ICC profile from ASUS
    Manufacturer-supplied monitor profiles are notoriously inaccurate and outright defective. They simply cannot be trusted. Do yourself a favor and buy a good calibrator, and this problem should go away. Yes, it's an added expense, but once you've made the (small) investment you'll never look back.
    Good candidates are x-rite i1 Display Pro, ColorMunki Display, or Spyder 4 Elite or Pro (the Spyder 4 Express uses the same sensor, but the software is too limited to be useful).
    Nov 4, 2013 12:18 PM   in reply to twenty_one
    Just in case you misunderstood what I wrote...
    ...let me rephrase that:
    If you can see any difference between them, that's an indication of a problem with the monitor profile.
