DW CS 6   File>Convert  DW CC is there a way to Convert doctype?
Nov 3, 2013 11:06 PM
Tags: #doctype #dreamweaver_cs6 #dreamweaver_cc
I was using DW CS6 and there is a File>Convert choice. Is there a way to Convert in DW CC?
Thanks for the help.
    Nov 4, 2013 1:50 AM   in reply to Daylightmagic
    There are two lines that are changed with a change in DOCTYPE, namely
    • the first line  - <!doctype html> and
    • the first line in the HEAD section - <meta charset="utf-8">
    Hence, if you do a site wide find and replace, you will achieve the same result.
    Nov 4, 2013 6:27 AM   in reply to Ben Pleysier
    Go to Modify > Page Properties > Title/Encoding and you can change the Doctype declaration, among other things, there.
    A find and replace would likely be faster if you need to do many pages though.
