phpandcss
where to post an upload variable
Nov 4, 2013 12:33 AM
I use a cart on my website and in order for it to process orders I need to post this variable on the form for the check out cart. does it go on the credit card processor form where user inputs the credit card info?
<input type="checkbox" title="Manual" name="cmd" value="_cart">
<input type="checkbox" title="Manual" name="upload" value="1">
<input type="checkbox" title="Manual" name="business" value="Your PayPal Email Address">
<input type="checkbox" title="Manual" name="item_name_1" value="Post Your Value Here">
<input type="checkbox" title="Manual" name="amount_1" value="x.xx">
<input type="submit" name="submit" value="submit">
</form>
    Nov 4, 2013 2:00 AM   in reply to phpandcss
    The posted results should be processed in the action page as in
    <form action="mypage.php">
    This action page can be the same page as the form or it could be a different page. This depends on how the script has been coded.
    I find the markup, that you have posted, a bit strange though. There is no label for the user to identify the input field.
    Nov 4, 2013 10:45 AM   in reply to phpandcss
    If you need to include a variable when the form is submitted, use a hidden field:
    <input type="hidden" name="some_variable" value="xyz123">
    Although it's called a "hidden" field, it's actually visible in the HTML source code, so it shouldn't be used for sensitive data.
    Nov 4, 2013 3:40 PM   in reply to phpandcss
    As David has suggested, you should use hidden fields as in
    <input type="hidden" name="cmd" value="_cart">
    <input type="hidden" name="upload" value="1">
    <input type="hidden" name="business" value="Your PayPal Email Address">
    <input type="hidden" name="item_name_1" value="Post Your Value Here">
    <input type="hidden" name="amount_1" value="x.xx">
    Also, you should ensure that the red-coloured values have been entered.
    As for the placement, because the fields are hidden - with the exception of the submit button - from view, it matters not, as long as they are inside the form. The submit button is usually placed at the end of the fieldset/form.
    Nov 4, 2013 6:28 PM   in reply to phpandcss
    1. Your form is meant to be processed by PayPal. PayPal requires information in a format that they understand, hence the fields that you have erroneously typed as 'checkbox'.
         If you have a product called 'Pull Up Widget' that has a price of 10 cents, then PayPal needs to know that. The two affected fields would look like
    <input type="hidden" name="item_name_1" value="Pull Up Widget">
    <input type="hidden" name="amount_1" value="0.10">
    2. Copy and paste the following into a new document and view in 'Live' view or in your favourite browser.  Note that hidden fields do not require a label.
    <!doctype html>
    <html>
    <head>
    <meta charset="utf-8">
    <title>Untitled Document</title>
    </head>
    <body>
    <h3>No Label</h3>
    <p>User has no idea what the checkbox is for</p>
    <form>
      <p>
      </p>
      <p>
      </p>
      <p>
      </p>
      <p>
      </p>
      <p>
      </p>
      <p>
      </p>
    </form>
    <hr>
    <h3>With Label</h3>
    <p>User is told what the checkbox is for</p>
    <form>
      <p>
        <label>
          input 1</label>
      </p>
      <p>
        <label>
          input 2</label>
      </p>
      <p>
        <label>
          input 3</label>
      </p>
      <p>
        <label>
          input 4</label>
      </p>
      <p>
        <label>
          input 5</label>
      </p>
      <p>
      </p>
    </form>
    </body>
    </html>
    3. Not sure what you mean.
    Here for a free Dreamweaver PayPal-extension and some information that will help
