Super
How to "analyze" multiple clips with "Warp stabilizer"-effect preset
Nov 4, 2013 5:52 AM
Is there a simple way to "analyze" multiple clips that have the Warp Stabilizer effect attached?
I have a sequence with 100 clips, which all have a customized Warp Stabilizer effect preset attached. I can attach the effect to all the clips very easily, but afterwards I have to manually press "Analyze" on each clip, which is quite irritating... Is there a shortcut?
I don’t use nesting because I have to tweak the effect-settings on some of the clips…
    Nov 4, 2013 8:35 AM   in reply to Super
    The Analysis happens automatically for me right after applying the clip.
    Nov 5, 2013 8:37 AM   in reply to Super
    Yeah, even when I apply to multiple clips, it starts immediately.
    Nov 9, 2013 2:07 PM   in reply to Super
    It's not a "custom preset" is it? Because those don't automatically begin analyzing...unfortunately. Otherwise, it should work...we do it ALL the time.
    Nov 11, 2013 11:42 PM   in reply to Super
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Yes, sadly custom presets with warp stabilizers don't work correctly. You have to go hit analyze manually for every clip. For you that may be quicker than changing your two settings for each clip. It is a bummer though. We actually use this effect several hundred times per week and prefer the "Position, Scale, Rotation" method in the settings but we can't use the custom preset because it doesn't properly re-analyze automatically like the default effect does. I'm not sure whether it'd be a bug report or a feature request (in my opinion it's a bug) but definitely report it to the link above.
