Karlsbad
How to raise total RMS to -20 while keeping peaks below -3db
Nov 4, 2013 10:46 AM
Tags: #audio #volume #raising #db #rms #audition_cs6 #audio_levels
Hi!
I'm editing an audio book and am having an issue getting my total RMS to -20 while keeping the peaks at or below -3db.
I've tried normalizing to a smaller db and then matching volume function to -20 total rms.  I've also tried that in reverse, matching volume first then normalizing using many different db levels but no matter what I do, my total rms won't stay at -20 without having peaks in the + 2 range.
I have 50 chapters to edit so I'd love to find out an automated way to accomplish this without having to spend a week going through manually to adjust the lower or higher frequencies.
Any suggestions?
Thanks so much for your help!
    Nov 4, 2013 2:07 PM   in reply to Karlsbad
    You may have to apply some audio compression/limiting to keep the peaks down whilst keeping the average level up. Set the levels to get your -20dB RMS and then squash the peaks. Normalisation won't do it because it adjusts the overall level. Have you tried the Speech Volume Leveler effect?
