light-style
Bridge Probleme auf 2.Monitor via mousewheel
Nov 5, 2013 1:02 AM
Bridge hat in der aktuellen Version ja das Problem, dass wenn sich Bridge auf dem 2. Monitor befindet das Scrollen via mousewheel nicht klappt. Hat jemand eine Lösung ( außer den Monitor umschalten) bzw. vielleicht denke Adobe ja mal über einen Bugfix nach. Im Netz gibt es nur Problemberichte aber keine Lösungen.
lg Andi
    Nov 5, 2013 9:13 AM   in reply to light-style
    Translation: Bridge has in the current version so the problem is that when Bridge on the 2nd Monitor is scrolling via mouse wheel does not work. Does anyone have a solution (except the monitor switch) or Adobe might think so times a bugfix for. In the network there are problem reports but no solutions.
    This gets confusing as usually the mouse functions are controlled by the mouse software.  If you run other programs does the mouse wheel work in second monitor?
    Nov 21, 2013 6:44 AM   in reply to light-style
    Wir haben exakt das selbe Problem und finden auch nur Fehlerbeschreibungen und KEINE LÖSUNGEN.
    Es ist einigermassen bedenklich, dass Adobe das vielfach beschriebene Problem schlichtweg ignoriert.
    Nov 21, 2013 7:25 AM   in reply to Marcel Ziegler
    Couple of notes from past threads.
    37. tinaTS,
      Aug 21, 2013 11:05 AM    in reply to LantzDesign
    Report
    Thank you for bringing this up - QE has looked at this and has determined that this is a known issue. Our apologies.
    Vote support for problem fix here http://feedback.photoshop.com/photoshop_family/topics/mouse_scrolling_ problem_in_bridge_cc
    23. MikeKPhoto,
      Jul 20, 2013 8:56 PM    in reply to LantzDesign
    Report
    I have this problem, not sure whether it is a Bridge or Microsoft issue - but leaning toward a Bridge issue as this is the only program I have that has this problem. But I do have a workaround, select an image in Bridge, hit the space bar to magnify, hit the space bar again to get back to normal view and viola the scroll wheel works and works until you loose focus with Bridge - lke switching to another window - when back in Bridge just repeat the hitting the space bar - works everytime for me
