CS6 FTP uploading does not work. Gives permissions error.
Nov 6, 2013 6:08 AM
I cannot upload files using the CS6 FTP facility. It works the first time but then gives a file permissions error. I assume it thinks the files on the server are set to read only. I am not using the check in facility as it is only me using it. It works on the same pc with MX or FileZilla so must be a CS6 setup issue. Any ideas ?
    Nov 6, 2013 6:18 AM   in reply to James Bagshawe (HTZ)
    Try toggling Passive FTP under your site settings and see if that changes anything for you.
    I'm not 100% on how to get there in DWCS6, I skipped that one, but in DWCC it's at...
    Site > Manage Sites > Edit > Servers > Edit > More Options
    Nov 6, 2013 8:15 AM   in reply to James Bagshawe (HTZ)
    Hmm, I've never run into that with DW's FTP (unless my permissions were messed up at the server level).
    Have you tried clearing DW's Cache file?
    http://forums.adobe.com/thread/494811
    That clears a lot of odd behaviors in DW. I'm not sure if it catches weird FTP problems though.
    Nov 6, 2013 9:22 AM   in reply to James Bagshawe (HTZ)
    Woops.
