Home/Support/
Forums
988 Views 8 Replies Latest reply: Jan 12, 2011 6:14 PM by cwm987 RSS
uruiamme Calculating status... 4 posts since
Dec 25, 2007
Dec 25, 2007 3:20 PM
The parameter is incorrect in Dreamweaver CS3 version 9
It was a long way to figuring this out. When synchronizing my website, I kept getting "The parameter is incorrect" in Dreamweaver CS3 for Windows, which means that it CRASHED the program and I was forced to kill the process in Task Manager to close it. Every time I ran the site sync or tried to view the problem file on the external website using ftp, I would receive this error and CRASH.
Here are some workarounds. First thing I figured out was that by deleting the particular file(s) which caused DW to crash, I could do a synchronize successfully. Sometimes, renaming the file on the external machine worked. The other workaround that I found from tech support was this.
Go into regedit and delete these keys:
HKEY_CURRENT_USER\Software\Adobe\Common\9
HKEY_CURRENT_USER\Software\Adobe\Dreamweaver 9
Of course doing this will remove all of your settings for Dreamweaver, but it would do the trick. I later found that there was a certain key that was causing the error, which I think is a cryptographic key of some sort, or some non-text field generated by DW. In any case, it took weeks of working with Adobe to correct this. Note that I was synchronizing many thousands of files, so this was pretty tedious. The sync would sometimes take hours due to the poor performance of ftp and our connection speed wasn't just perfect.
When I told the tech support person that I could send her my Registry settings so she could reproduce the error and fix Dreamweaver, she refused. She was not interested in ever fixing the application to prevent it from locking up and freezing due to this error. The whole ftp download and upload scenario in DW is spartan... the way you wait for hours and can't do any meaningful work while a sync occurs. I would much prefer to use a more intuitive ftp program than watch DW do this... all of the new ftp clients can do things in parallel threads, but DW is stuck in 1997, do one file at a time.
So while I got my issue resolved to Adobe's liking, I prefer to have the app fixed. But me turning blue in the face wasn't going to have it happen, so I stopped holding my breath.
  • Tobi UK Calculating status... 1 posts since
    Mar 29, 2008
    I tried the work-arounds discussed to no avail.
    I found that manually going through the site, firstly folder by folder then file by file I came across one file that Dreamweaver didn't like. After trying to reupload and it still hanging, I copied all the code into a blank document, deleted the original file, then saved the new document with the deleted file's name. I uploaded this and the problem was gone. Hope this is useful.
    Tobi
  • gkoehler Calculating status... 1 posts since
    Apr 29, 2008
    I left the registry alone. And I too found the file that it was hanging up on - a PDF doc, for some reason. Deleted it. And then it worked fine.
  • Razone2005 Calculating status... 1 posts since
    Oct 6, 2005
    Same issue with me - was a PDF file; you would think Adobe would figure out how to resolve errors with their own file types...
  • Calculating status... 1 posts since
    Jan 7, 2009
    I had the same issues during synchronization. I was able to go through each folder like some of the other suggestions to narrow it down and find the folder and then the file that caused be problem. In my case, I found that a "hidden" Windows thumbnail caching file named Thumbs.db was blowing up the sync everytime. Don't know if it happens to other Windows users, but if that file happens to be uploaded on webserver---then I get errors. It works fine after I delete it. However, deleting it was another issue by manually FTPing on to the webserver and deleting it via the command prompt. Good Luck to others.
    I would use the method of syncing folder by folder and then file by file first before ever deleting registry keys.
    Razone2005---as far as it being an Adobe PDF... I don't think that it is a Dreamweaver vs PDF issue as much as it might be attributed to the FTP Hosting webserver and your personal local files. I used a program called WS-FTP Pro to transfer files with socket errors, so it choked the same way as Dreamweaver.
  • jonathan-7007 Calculating status... 1 posts since
    Jan 22, 2009
    How are all of you determining WHICH file is causing the problem? It sounds like you resorted to FTP'ing one at a time until the process hung, and assuming that file that was called to sync caused the hang. Is that right? I need to learn about this as I am moving lots of files back and forth at the moment using FileZilla (v3.2, I believe.)
    I have freeze up problems that are different: clicking in the Property panels at the bottom of Design View is freezing up my Lenovo laptop hard enough that CTRL-ALT-DELETE doesn't break through it.
    Jonathan
  • Kryptonian_Shinobi Calculating status... 20 posts since
    May 7, 2007
    Hi Jonathan,
    To do that, I believe you can try a suggestion from the following
    Error "Parameter is incorrect"
    http://www.adobe.com/go/fbfd45c3
  • cwm987 Calculating status... 1 posts since
    Jan 12, 2011
    Late reply, but figured i'd post my fix since I've had this problem, and this page came up at the top of google search results..
    When I've had this problem, the corrupt file is missing "Last Modified" information. Simply find the file with missing "Last Modified" (either through Windows Explorer on the local drive, DW FTP, or whatever), then manually cut & paste the contents of the file into a new file, "Save As" the old file name, and "Put". Then try to sync again.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
