Spud640
How do I activate the "Signature" options of a PDF document created 11/8/13
Nov 8, 2013 8:24 PM
How do I activate the "Signature" options on a PDF document?
  • George Johnson
    Aug 11, 2002
    Nov 8, 2013 9:51 PM   in reply to Spud640
    You need to provide more information. Are you asking about enabling signatures in Acrobat or Reader, and do you mean digital signatures or e-signatures (EchoSign).
    Nov 13, 2013 2:38 PM   in reply to Spud640
    Hi Spud640,
    Are you using Acrobat or Reader and which version? The reason I ask is the UI changes between versions and I want to make sure I give you a set of steps that will make sense.
    Steve
    Nov 14, 2013 4:16 PM   in reply to Spud640
    Hi Spud640,
    • Click the Sign button on the toolbar to open the Sign panel
    • The panel is divided into three sections, expand the I Need to Sign section
    • Click the Place Signature button under Fill & Sign
    • Select the Draw my signature radio button
    • Use your mouse to create a signature in the large edit field
    • Click the Accept button
    • At this point the cursor is the signature, where ever you click in the file will place this image,
    • Unless you clear the signature, the next time you select the Place Signature button you won't see the dialog above, it will just go right to turning the cursor into your signature.
    Steve
