Timeline vs Button Overrides
Nov 10, 2013 4:59 AM
I wanted to return to top menu at end of timeline if navigating by selecting a button, so set up my timeline overrides accordingly.
But it didn't work properly.
It did work when I set up the button overrides.
I Googled but can't find any info about what each does.
Could someone please help me with the difference between button overrides and a timeline overrides.  Thanks
    Nov 10, 2013 9:27 AM   in reply to VidShooter
    Overrides do work, but unless you thoroughly understand them, try to avoid them. In most cases, Chapter Playlists or alternate navigation will do what you are attempting.
    That said, for example, if a button is linked to Timeline 1 (that has an end action of going on to Timeline 2), and the button has no override set, Timeline 1 executes its end action and goes to Timeline 2. If the button has an override of "last menu," then Timeline 1 does not execute its own end action, but the override action from the button that called it - and returns to the last menu.
    Timeline overrides do the same thing: if Timeline 2 has an end action of Timeline 3, and Timeline 1 (with an end action of Timeline 2 and no override set) links to Timeline 2, then Timeline 2 will execute its end action and continue on to Timeline 3. If Timeline 1 has an override set for "last menu," then when it starts Timeline 2, Timeline 2 will end by going back to the last menu.
    Nov 11, 2013 5:40 AM   in reply to VidShooter
    It would be hard to disagree with that, but, if yoiu think about it, the overriding action is on the "next" object either way. Part of the oddity, is the purpose of a button is to link, and it has no "end action" because its end action is the link. A timeline has its own end action, which it cannot override (the override is by the object that calls it), so its override, just like a button, is on the next object.
    Thanks for reporting your test!
