billrosspaxedi
SSL not working
Nov 10, 2013 2:10 PM
I have Coldfusion 10 and Coldfusion Builder 2.0 installed entirely on my local Windows 8 machine. I'm using the builtin Tomcat server.
I'm accessing the server using Remote Data Services (RDS).
When I try to run my application it won't run because the IDE runs it as https://localhost:8500/MyApp
If I copy the link and change it to http://localhost:8500/MyApp then it works.
I have both TLS and SSL enabled in Internet Explorer.
I understand that if you use JRun then you have to install a certificate, but I'm not using JRun.
So how can I either get CF Builder to not put the "s" in or get Tomcat to accept it?
Bill
    Nov 12, 2013 9:40 AM   in reply to billrosspaxedi
    Hi
    Try the steps mentioned below
    Open Command Prompt as Run as Admin and change the directory to  C:\ColdFusion10\jre\bin
    Type the command below and press Enter
    keytool.exe -genkey -alias tomcat -keyalg RSA
    Enter the password : changeit
    Now in the this location: C:\Users\username you will get a .keystore
    Open the server.xml of the ColdFusion instance : C:\ColdFusion10\cfusion\runtime\conf
    Uncomment the SSl/https
      <Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true"
                   maxThreads="150" scheme="https" secure="true"
                   keystoreFile="C:\Users\username\.keystore" keystorePass="changeit" keyAlias="tomcat"
                   clientAuth="false" sslProtocol="TLS" />
    NOTE : You need to add the keystore info in it as I did above
    Save and restart the ColdFusion 10 Application server service
    Now open https://localhost:8443 and it will work
    NOTE : The https port in server.xml is 8443
    VJ
    Nov 12, 2013 11:28 AM   in reply to billrosspaxedi
    billrosspaxedi wrote:
    The problem is probably related to the fact I’m unable to start my localhost server:
    Is your hosts file (C:\Windows\System32\drivers\etc) looks like this?
    You need to add 127.0.01 for localhost in the hosts file.
    VJ
    Nov 12, 2013 12:00 PM   in reply to billrosspaxedi
    Restart the machine. What happens when you try 127.0.0.1 instead of localhost? Then try
    Nov 12, 2013 12:09 PM   in reply to billrosspaxedi
    As you mentioned above that if you try http://localhost:8500, it works which means there is no issue with the localhost then.
    Go to C:\ColdFusion10\cfusion\bin  and take a backup of jvm.config
    Now open the jvm.config, Add following argument in jvm.config after the argument line (not in a new line)
    -Djavax.net.ssl.trustStore=C:\\ColdFusion10\\jre\\lib\\security\\cacer ts -Djavax.net.ssl.trustStorePassword=changeit
    Then restart the ColdFusion 10 Application server service and run https://localhost:8443
    VJ
Bookmarked By (1)
