KalleK
Preserving forced returns in a cross-reference
Nov 11, 2013 6:30 AM
Hi.
I have a document where I would like to cross-reference paragraphs that have forced returns in them.
Unfortunatelly the returns are lost.
Any idea on how to accomplish this?
I am using unstructured FrameMaker 10.
Thank You
Peter
    Nov 11, 2013 6:40 AM   in reply to KalleK
    Use Text Insets instead of xrefs
    Nov 11, 2013 7:43 AM   in reply to Jeff_Coatsworth
    Can a document text inset from itself (assuming that's the requirement here)?
    If so, wouldn't the target text need to be in a unique Flow?
    I'm thinkin' it might be easier to craft the original text as a variable, including hard returns ( \r ) as needed, then just use the var everywhere needed.
    Nov 11, 2013 7:47 AM   in reply to Error7103
    That would probably be even easier ;>)
    Nov 11, 2013 7:52 AM   in reply to Jeff_Coatsworth
    I always teach xrefs, variables, and text insets back-to-back, as they're kinda related. Each would work to a degree, but it just depends on the size of the reused content.
    For the TI, you could have the common text in a named flow on the reference page. The flow could be in the content doc, or in a separate doc containing one or more named flows.
    Nov 12, 2013 6:31 AM   in reply to KalleK
    You might want to also have a look at Steve Kubis' Auto-Text tool. See: http://www.siliconprairiesoftware.com/Products.html
    This allows you to set up re-usable content snippets that are fully formatted.
    Nov 12, 2013 7:39 AM   in reply to KalleK
    @Peter: Well, since you asked...
    I cover all of these in the 700 page book listed in my signature.
    -Matt
    Matt R. Sullivan
    co-author Publishing Fundamentals: Unstructured FrameMaker 11
    Nov 12, 2013 12:18 PM   in reply to KalleK
    Text Insets work, as long as you don't need automatic Xrefs to a Glossary.
    Suppose the first element in your grammar is the Abend keyword.
    View > Reference Pages
    View > Grid Lines
    Special > Add Reference Page
    Name: [ Syntax01 ]
    [ Add ]
    If the language is extensive, you are apt to need multiple Reference Pages.
    From the graphics tool pod, select Text Frame tool.
    Draw a suitably sized text frame on grid.
    Graphics > Object Properties
    Flow: Tag: [ Abend ]
    [ Set ]
    In the text frame, author and format your grammar for the Abend keyword.
    View > Body Pages
    At the desired insertion point in the narrative:
    File > Import > File
    {file self}
    <*> Import by Reference
    [ Import ]
    Flow to Import:
    <*> Reference page Flow [ Abend ]
    Formatting of Imported Flow:
    <*> Reformat Using Current ...
    or
    <*> Retain Source's Formatting
    Updating of Imported Flow:
    <*> Automatic
    Repeat for remainder of grammar. Add new Syntax## Ref Pages as existing ones fill up.
    Nov 19, 2013 6:26 AM   in reply to Error7103
    Not an issue. It turns out that named flows can exist on Body pages too. You can create a text frame in an ancored frame, for example, and give it a unique Flow name.
    This would allow the creation of a syntax reference, where each term/phrase is defined in a uniquely named flow. Use of the fully-formatted syntax definitions elsewhere in the document/book would be Text Insets. The re-uses would be hypertext links to the syntax ref, that work properly.
    As with all Text Insets, of course, an end-of-paragraph comes in with the text. As I recall, Run-In formatting can be used to deal with that if it's a problem.
