Need Help - Text Created in Illustrator Blurry when Transfered into PS
Nov 11, 2013 8:04 AM
Tags: #illustrator #photoshop #text #pixelated #blurry
Hello,
I've been working on items in Illustrator, and noticed a HUGE change when I transfer them into Photoshop.  What I am doing is creating images (and text) in Illustrator.
Then I select, Control + C to copy, then I paste into my 300dpi document in Photoshop to add textures, etc.  Once they are brought in... the text is pixelated and not clear like it is in Illustrator.
What am I doing wrong?  Or how do I fix this?
Left (is the Photoshop Image) AFTER Transfer ------ Right (Original Image in Illustrator)
https://api.monosnap.com/image/download?id=Ct5k751dEpmxJ7jfgRVId7QB7
    Nov 11, 2013 8:15 AM   in reply to sahlink
    You did not say if your screenshots are at 100% or zoomed in, or if this is for digital or print,  as that also has alot to do with this. How does this look at 100% scale in photoshop, 1 pixle data = 1 pixel of screen reoslution?
    300 dpi is the most common resolution for continuos tone CT in printing.  Linework Resolution is between 1200 & 3386 dpi.
    Nov 11, 2013 9:56 AM   in reply to sahlink
    There is something wrong here, your M should look like mine below. You have some enexplained spots going on rather than a solid color.  Are you using some raster effects on your type, than that is your problem.
    Need to know more about the construction of your Illustrator file to help. We may be able to fix this with a mask for the type over a texture, but then I am just guessing at what you have, so don't want to say anymore.
    Nov 11, 2013 11:06 AM   in reply to sahlink
    Which version of Illustrator are you using?
    What version of Photoshop?
    Can you provide sample files (.ai and .ps) ?
    Nov 11, 2013 2:42 PM   in reply to sahlink
    I opened your CC file in CS6, and it looked rastered. I opened the smart object, copied and pasted a new smart object and now this looks good now. (I had to substitute Arno Pro Bold since I did not have your font). This may be a CC issue, so if anyone with CC can help out, try downloading the file.
    Screen Shot 2013-11-11 at 4.36.51 PM.pngScreen Shot 2013-11-11 at 4.36.57 PM.png
    Check your clipboard settings against mine. Try from Illsutrator saving as a .eps and placing taht .eps as a smart object.
