Lycokalon
Flash CS4: remove panel while testing
Nov 11, 2013 8:41 AM
It appears a panel with  "File", "View", "Control" and "Debug" menus in the SWF window while testing. How can I remove it ? Thanks.
    Nov 11, 2013 9:27 AM   in reply to Lycokalon
    Pretty sure you can't remove those menus while testing. They're there for that very reason, to help you test the SWF. If you really want to remove it you can always publish the SWF and look at it in the browser but you'll have "the browser" wrapped around it which isn't much better.
    Nov 12, 2013 8:31 AM   in reply to Lycokalon
    How are you viewing the SWF? If you're just clicking on it in your filesystem to open then by default it will be opened by "Flash Player". Those menus are a standard part of the Flash Player application.
    As mentioned, if you drag your SWF into a browser you will not see those menu items.
    Also if you intend to run the SWF itself you can export a Projector (CS6 and below, not supported on CC). That will make an executable (.exe for Win, .dmg for Mac) which will not contain these menu items.
    Nov 12, 2013 11:34 AM   in reply to Lycokalon
    It's normal behavior of Flash Player. If you're all set please mark helpful/correct so we can filter unanswered questions. You're welcome and good luck!
