kishoreda
Encore CS4 creating multiple DVDs
Nov 11, 2013 11:44 AM
Windows 7
Ram 6GB
Encore CS4
Gentlemen !
I have a footage , which is about 7 hours long(Video ntsc) , besides cutting the footage into few pieces, is there any way I can create a set of DVDs, like a let's say DVD1 through 3 or 4
Here is what I do
I import my 7 hours footage , then I create a "TimeLine" on the time line I set chapter marks and I assign each chapter mark to a scene on the main page.
Before I used to do the same thing with 2 or 3 hours footage and it would work fine , but now that my footage is too long , its says all videos cannot fit on one disk , so
Is there any way I can put them on several DVDs ?
Thanks.
    Nov 11, 2013 12:29 PM   in reply to kishoreda
    Export smaller segments from Premiere Pro and then use Encore to author individual DVDs
    If you are asking if there is a way to SPAN discs so the menu is only on disc 1 and added video is on disc 2 and onward, I don't believe that is part of the DVD specification
    Each DVD is a discrete, standalone entity
    Link to DVD Demystified FAQ http://forums.adobe.com/thread/544206
    Nov 11, 2013 12:32 PM   in reply to kishoreda
    Create the separate pieces in Premiere Pro, and export as MPEG2-DVD, ready for Encore to put on disk.
    Encore does not do a good job when you put a very large timeline in and crop it, etc.
    4 disks will make it easier to break them up in terms of content. You are looking to keep the time under 2 hours per disk max. You can make multiple timelines per disk if that suits the material better.
    You'll need to calculate the bitrate to use for the export from PR. If you calculate the fullest disk, you can use those settings for all of them. But you can calculate it for each disk, and get somewhat better quality on the disks that are not as full.
