VikramRaman
How to change play position in sound class
Nov 11, 2013 8:38 PM
Tags: #change #play #in #position #sound_equalizer #equalizer
I have developed a small application for testing 5 band equalizer in flex. I found the code in this link Flex Equalizer The equalizer works fine.But i am not able to seek the desired position  while playing the mp3 file. If i try to change position. Its plays from the begining position only.How to solve this problem?
Following is my code....
import __AS3__.vec.Vector;
import mx.events.FlexEvent;
import spark.components.VSlider;
public static const BUFFER_SIZE:int = 8192;
public static const SAMPLE_RATE:int = 44100;
private var _Position:Number=0;
private var timer:Timer = new Timer(1000);
private const _soundURI:String = "testfile.mp3";
private var _out_snd:Sound = new Sound();
private const _eqL:EQ = new EQ();
private const _eqR:EQ = new EQ();
private var _loop_snd:Sound = new Sound();
// For storing dynamically created VSliders
private const _sliders_vect:Vector.<VSlider> = new Vector.<VSlider>();
private var _channel:SoundChannel = new SoundChannel();
private var _samples:ByteArray;
protected function view1_initializeHandler(event:FlexEvent):void
// TODO Auto-generated method stub
            timer
.addEventListener(TimerEvent.TIMER,timerFunction);
            pgHolder
.addEventListener(MouseEvent.CLICK,seekf);
            setupEQ
            loadSound
private function timerFunction(event:TimerEvent):void
_Position = _channel.position;
            pgHolder
.value=_Position;
private function seekf(event:MouseEvent):void
            _channel
.stop();
_Position = (pgHolder.contentMouseX/pgHolder.width)*_loop_snd.length;
            startPlay
private function loadSound():void
_Position=0;
            _loop_snd
.addEventListener(Event.COMPLETE, loadSoundComplete);
            _loop_snd
.addEventListener(IOErrorEvent.IO_ERROR, loadSoundError);
            _out_snd
.addEventListener(SampleDataEvent.SAMPLE_DATA, processSound);
            _loop_snd
.load(new URLRequest(_soundURI));
private function loadSoundComplete(event:Event):void
            pgHolder
.minimum=0;
            pgHolder
.maximum=_loop_snd.length;
            timer
.start();
            startPlay
private function startPlay():void
            _channel
=_out_snd.play(_Position);
private function loadSoundError(event:Event):void
            trace
("loadError");
// Create Sliders for changing EQ gain
private function setupEQ():void
var slider:VSlider;
for (var i:int = 0; i < _eqL.gains.length; i++) {
                slider
= new VSlider();
                slider
.x = (i * 35);
                slider
.y = 20;
                slider
.value = .9;
                slider
.maximum = 1;
                slider
.snapInterval=0.1;
                slider
.minimum = 0;
                slider
.addEventListener("change", changeEQHandler);
                addElement
(slider);
                _sliders_vect
[i] = slider;
var event:Event = new Event("change");
            changeEQHandler
(event);
private function processSound(event:SampleDataEvent):void
//trace("loading");
if(_Position>=_loop_snd.length)
                _channel
.stop();
            _samples
= new ByteArray();
var len:Number = _loop_snd.extract(_samples,BUFFER_SIZE);
var i:int=0;
var l:Number;
var r:Number;
if ( len < BUFFER_SIZE ) { // If end of MP3, start over
                len
+= _loop_snd.extract(_samples,BUFFER_SIZE-len,0);
            _samples
.position = 0;
while (i < BUFFER_SIZE) {
event.data.writeFloat(_eqL.compute(_samples.readFloat()));
event.data.writeFloat(_eqR.compute(_samples.readFloat()));
                i
// Update EQ gains when sliders are changed
private function changeEQHandler(event:Event):void
var i:int = 0;
for(i = 0; i < _eqL.gains.length; i++){
                _eqL
.gains[i] = _sliders_vect[i].value * 2;
for(i = 0; i < _eqR.gains.length; i++){
                _eqR
</fx:Script>
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<s:HSlider width="100%" height="100%" id="pgHolder">
</s:HSlider>
