create DIV first?
Nov 13, 2013 6:46 AM
In inserting images into a fluid grid layout, do I first have to create a DIV and then insert the image into the DIV? Thanks, Kevin
    Nov 13, 2013 7:13 AM   in reply to KevinB9
    Depends on where the image will be used. Eg. <header>, <footer>, <aside>, <article>, etc...  If you're asking if you need another div within the main structure to hold the image,  no.  But you could insert it inside a <figure> tag if that's how it will be used.
    Nancy O.
    Nov 13, 2013 9:44 AM   in reply to KevinB9
    By default, FG Layouts re-scale images to viewport width up to the native image size.
    img {max-width:100%}
    However, this won't work if your HTML code contains explicit img height & width values.  You would need to remove them.
    Nancy O.
