dbegalka
Unwanted lines when using effects.
Nov 13, 2013 7:23 AM
Having much trouble with unwanted thin lines when using outlined text with multiple effects - outer glow & bevel and emboss. Typically the lines show through the outer glow effect in the color of the background. It is then especially noticable with the darker background I used for this layout. The lines are not visible on screen but show up in printing. I have also tried saving as PDF and then printing but no difference.
Here is a scanned portion of the layout.
Any help would be greatly appreciated!
    Nov 13, 2013 7:46 AM   in reply to dbegalka
    These are probably transparency artifacts. Are you printing direct from ID, or exporting a PDF and printing that? If the PDF, what settings do you use? What printer?
    Nov 13, 2013 8:05 AM   in reply to dbegalka
    Transparency artifacts like this are highly dependent on the output device. Are you using a postscript driver for the BizHub? If not try it.
  • Rob Day
    Oct 16, 2007
    Nov 13, 2013 8:15 AM   in reply to dbegalka
    In ID or Acrobat's  Print>Advanced dialog can you choose a Transparency Flattener preset? Is it set to High Resolution?
    Nov 13, 2013 8:20 AM   in reply to dbegalka
    That doesn't necessarily mean you are actually using the postscript driver...
  • Rob Day
    Oct 16, 2007
    Nov 13, 2013 9:06 AM   in reply to dbegalka
    The transparency flattener preset was set to medium resolution.
    If it's transparency stitching then the flattener preset you use in the print driver would make a difference. Try High resolution or make a flattener preset that has a heavier raster balance. Here's a flattened PDF/X-1a test with low res vs. a customized high res:
    The custom flattener on the left has no stitching at any zoom view
  • Rob Day
    Oct 16, 2007
    Nov 13, 2013 9:42 AM   in reply to dbegalka
    Raterizing could slow your printer down. You might not need it for all transparency—I think effects like emboss tend to stitch more.
