Jquery autocomplete with json
Nov 14, 2013 9:43 AM
Does anyone have a full working example of Jquery autocomplete with json that works?
I can't get any of the examples that I am finding online to work.
    Nov 15, 2013 8:01 AM   in reply to pjunkie
    Please define "doesn't work". Put your code online somewhere so that we can see it running.
    Nov 17, 2013 2:06 AM   in reply to pjunkie
    AS you know, the CFC just replaces the file by outputting exactly the same data as the file would. Without seeing HTTP traces, JavaScript error logs etc etc it's very hard to give an answer or see what is wrong. Please put your code online so I can take a look at it actually running.
    Btw, my answer here http://forums.adobe.com/thread/1319717?tstart=0 refers to a script that uses Ajax already, and the data is JSON encoded too.
    Nov 18, 2013 4:16 AM   in reply to pjunkie
    jQuery is nothing to do with ColdFusion. You are just using ColdFusion to serve out data from a database query. You will have to find a way to get your code online so we can see it, since there are many dozens of reasons as to why code does not work the way it should.
    Nov 18, 2013 11:51 PM   in reply to pjunkie
    The ongoing thread here http://www.houseoffusion.com/groups/cf-talk/thread.cfm/threadid:64866 is really saying the same thing you and I are, namely that the data is not in the correct format (as you know). That thread made mention to this article: http://www.petefreitag.com/item/720.cfm. The leading "//" on the front of that data shows that secure JSON is enabled. This "//" prefix needs to be removed from the data. Can you put this in your code to turn secure JSON off and then see what response you get?
    <cfset this.secureJSON = false>
    Nov 19, 2013 6:19 AM   in reply to pjunkie
    Well done, the format plain must be a simple JavaScript array then? I think if you had secureJSON off and the plain return format, it would have worked too. Btw JSON comment prefixes can be disabled via the CF admin too. All's well that ends well.
