Cannot open Illustrator after update. Urgent fix required please.
Nov 18, 2013 4:04 AM
Tags: #illustrator #help #error #font #mac #bug #creative_cloud #cc
I have just updated Illustrator CC today in the hope that the bugs I had would be fixed. Now I cannot open Illustrator at all. I get the error message which says I do not have Verdana installed. I am using Suitcase Fusion 5 (v16.0.4) and I have checked and I have two versions of Verdana (one Microsoft which I can turn off the other is locked), both of which are OpenType Fonts.
I've tried having both open and then turning the Microsoft one off. The other I cannot turn off. Illustrator will not open at all. I've tried re-booting my machine without success. I could at least open Illustrator before the update with exactly the same fonts available.
Please can someone help with this urgently!!!!!
It would help if Adobe, Apple and Extensis would actually talk to each other and write code that works rather than release bug fix after bug fix that still doesn't work!!!!!!
System:
iMac 3.4 GHz Intel Core i7
16 Gb 1600 MHz DDR3 RAM
Mac OSX 10.9
Screen Shot 2013-11-18 at 11.42.24.pngScreen Shot 2013-11-18 at 11.59.27.png
Replies 1 2 Previous Next
    Nov 18, 2013 4:15 AM   in reply to John@3cdp
    Hi John,
    Will it be possible for you to join the connect session: https://my.adobeconnect.com/rbhunwal
    I want to look into this issue.
    Thanks & Regards,
    Raghuveer
    Nov 18, 2013 4:31 AM   in reply to John@3cdp
    Same problem…
    Nov 18, 2013 4:32 AM   in reply to Cédric Brogniez
    Cedric can you join the session. I want to have a look into the issue.
    Regards,
    Raghuveer
    Nov 18, 2013 5:31 AM   in reply to Raghuveer Singh Bhunwal
    Sorry, i can't join the session now, i'm at work.I have the same problem but I don't have the same message.
    Nov 18, 2013 5:47 AM   in reply to Cédric Brogniez
    I Have the same Problem as Cédric, Just updated and it now crash. Should I re-install?
    Nov 18, 2013 6:12 AM   in reply to David Vroye
    David, try to enable the Verdana font family if it is disabled and if this is another issue then please give me a moment to debug that. You can join my connect room:
    https://my.adobeconnect.com/rbhunwal     after a few minutes.
    Thanks and Regards,
    Raghuveer
    Nov 18, 2013 6:52 AM   in reply to Raghuveer Singh Bhunwal
    Same here under win7 x64.
    After upgrade illustrator wont start
    Nov 18, 2013 7:00 AM   in reply to Cédric Brogniez
    I check my verdana font, but always the same problem since the update…
    Nov 18, 2013 7:03 AM   in reply to Raghuveer Singh Bhunwal
    Hi, I'm having the same problem
    Illustrator keeps crashing
    Help, please!
    Nov 18, 2013 7:22 AM   in reply to John@3cdp
    I d'ont use suitcase fusion, i've activate verdana with fontbook, but i've got always the same problem.
    Nov 18, 2013 7:26 AM   in reply to Cédric Brogniez
    Same here, I think it has nothing to do with fonts.
    It's just... I open Illustrator and it crashes, I reopen and it happens again and again and again...
    Nov 18, 2013 7:31 AM   in reply to jimotd
    Jim can you join the connect session ?
    Thanks & Regards,
    Raghuveer
    Nov 18, 2013 8:23 AM   in reply to John@3cdp
    I'm agree with john.
    Can i download another version (before 17.0.1) of illustrator somewhere ? Still this update, i can't work !
    Nov 18, 2013 8:25 AM   in reply to John@3cdp
    I tried to remove all non default plugins and extension, to unistall all and reinstall, nothing.
    This is a trace of the crash in win7 pro x64.
    Firma problema:
      Nome evento problema:    BEX64
      Nome applicazione:    Illustrator.exe
      Versione applicazione:    17.0.0.260
      Timestamp applicazione:    528213c9
      Nome modulo con errori:    StackHash_1dc2
      Versione modulo con errori:    0.0.0.0
      Timestamp modulo con errori:    00000000
      Offset eccezione:    0000000000000000
      Codice eccezione:    c0000005
      Dati eccezione:    0000000000000008
      Versione SO:    6.1.7601.2.1.0.256.1
      ID impostazioni locali:    1040
      Informazioni aggiuntive 1:    1dc2
      Ulteriori informazioni 2:    1dc22fb1de37d348f27e54dbb5278e7d
      Ulteriori informazioni 3:    eae3
      Ulteriori informazioni 4:    eae36a4b5ffb27c9d33117f4125a75c2
    Nov 18, 2013 8:28 AM   in reply to jimotd
    I seem to be having the same issue, crash on open with no regards to fonts and I don't use any third-party application for fonts.
    Raghuveer - I can join the connect session?
    Nov 18, 2013 8:30 AM   in reply to max.schwanger
    Same issue
    Problem signature:
      Problem Event Name:          BEX64
      Application Name:          Illustrator.exe
      Application Version:          17.0.0.260
      Application Timestamp:          528213c9
      Fault Module Name:          StackHash_1dc2
      Fault Module Version:          0.0.0.0
      Fault Module Timestamp:          00000000
      Exception Offset:          0000000000000000
      Exception Code:          c0000005
      Exception Data:          0000000000000008
      OS Version:          6.1.7601.2.1.0.256.48
      Locale ID:          1033
      Additional Information 1:          1dc2
      Additional Information 2:          1dc22fb1de37d348f27e54dbb5278e7d
      Additional Information 3:          eae3
      Additional Information 4:          eae36a4b5ffb27c9d33117f4125a75c2
    Nov 18, 2013 8:41 AM   in reply to foeoneone
    I have debugged a few user machines. Can you guys please post the following information:
    1) OS language
    2) OS Version
    3) Application Language
    4) Printer or Printer driver details if installed.
    5) If you have submitted the crash logs throgh Adobe Crash Reporter than please provide the ID's with which you have submitted them.
    Thanks and Regards,
    Raghuveer
    Nov 18, 2013 8:41 AM   in reply to Raghuveer Singh Bhunwal
    Hey Rghuveer,
    1) OS language - US English
    2) Application Language - US English
    3) Printer or Printer driver details if installed.
         -Epson WP-4020 Series
         -HP Color LaserJet 2605dn
         -HP LaserJet P2035n
         -HP Officejet Pro X476dw MFP
    4) If you have submitted the crash logs throgh Adobe Crash Reporter than please provide the ID's with which you have submitted them.
         Not sure where to locate the ID after I've submitted?
    Nov 18, 2013 8:46 AM   in reply to max.schwanger
    The ID which you write to submit the crash report. See the attached screen shot:
    Regards,
    Raghuveer
    Nov 18, 2013 8:46 AM   in reply to Raghuveer Singh Bhunwal
    thanks Raghuveer
    1) OS language: Italian
    2) OS Version: Win7 Ultimate x64
    3) Application Language: Italian
    4) Printer or Printer driver details if installed:
    Adobe pdf
    Samsung clx3170n
    5) If you have submitted the crash logs throgh Adobe Crash Reporter than please provide the ID's with which you have submitted them:
    I don't have a crash reporter
    Nov 18, 2013 8:49 AM   in reply to Raghuveer Singh Bhunwal
    My ID is max.schwanger@industryweapon.com
    I must have clicked the "Don't Send-Don't Ask Me Again" button because the Adob crash report is no longer showing, just the Mac OS report. Is there a way to reset that?
    Nov 18, 2013 8:51 AM   in reply to Raghuveer Singh Bhunwal
    1) OS language - French
    2) OS Version OS X 10.9
    3) Application Language - French
         -Brother DCP-9270CDN
         -Epson Stylus Photo 1500 th
    5) ID: brogniez.cedric@orange.fr
    Thnx.
    Nov 18, 2013 8:53 AM   in reply to Marco Perra
    OS Language: English
    OS Version : Windows 7 SP1 64bit
    App Language: English
    Printers:  Epson Stylus NX4000
                   Roland SP-540v
                   Roland VW
    Nov 18, 2013 8:54 AM   in reply to max.schwanger
    Go to Installed Application folder and right click on 'Adobe Illustrator CC' app and choose to 'Show Package Contents'.
    Inside it select 'Contents'>Frameworks>AdobeCrashReporter.framework>Required>
    Double click on 'Adobe Crash Reporter.app' and choose the first option (default) or select the appropriate option.
    Nov 18, 2013 8:58 AM   in reply to Raghuveer Singh Bhunwal
    When I open Adobe Crash Reporter, nothing happens.
    Nov 18, 2013 9:04 AM   in reply to max.schwanger
    same as max…
    Nov 18, 2013 9:07 AM   in reply to Raghuveer Singh Bhunwal
    in windows there is no Adobe Crash Report
    Nov 18, 2013 10:39 AM   in reply to Marco Perra
    Having the same issue since updating.
    1) OS language: English
    2) OS Version: OSX 10.9
    3) Application Language: English
    4) Printer or Printer driver details if installed.: Cannon MX870
    5) christy.case@gmail.com
    Nov 18, 2013 11:08 AM   in reply to bloom 7
    Thanks to Madge for going forward into this and isolating the issue.
    Please add the "Verdana Font Family" to the System Fonts folder and then using font management software try to disable all the other fonts except the System Fonts.
    Regards,
    Raghuveer
    Nov 18, 2013 11:22 AM   in reply to Raghuveer Singh Bhunwal
    I had the problem not related with Verdana. I had to reinstall. It worked for me.
    Nov 18, 2013 11:42 AM   in reply to Raghuveer Singh Bhunwal
    It Worked ! Thanks for the tip.
    Nov 18, 2013 11:42 AM   in reply to John@3cdp
    I was facing the exact same problem and I found that disabling LASTRESORT font worked for me.
    Removing the font does not solve the issue. For me LASTRESORT font has to be installed BUT disabled in order for Illustrator cc updated to 17.0.1 to work. Strange.
    I did copy Verdana family to the System/Library/Font folder and Tahoma to the Library/Font folder as advised.
    Hope this is helpful. Let me know if this works for anyone else.
    Nov 18, 2013 12:06 PM   in reply to summersea
    This does not work for windows. There is no system/library/font folder. My fonts folder in the windows directory already has verdana in it. I've tried re-installing. I've tried running the 32bit version instead. Still crashes. Direct result of the update, worked fine before.
    Nov 18, 2013 12:12 PM   in reply to foeoneone
    same as foeoneone
    Nov 18, 2013 12:20 PM   in reply to foeoneone
    Does it have the entire Verdana font family as well as the entire Tahoma font family?
    Nov 18, 2013 12:36 PM   in reply to Larry G. Schneider
    4 fonts verdana, 2 fonts tahoma. Those are the entire family unless you are talking verdan "pro" which has 20 fonts. I'm assuming that isn't necessary. They were there before the update, and are still there after the update, so the real question is, what broke in the update? not wether or not I'm deleting system fonts willy nilly.
    Nov 18, 2013 12:41 PM   in reply to foeoneone
    Then have you added any other fonts recently. Have you tried verifying the fonts?
1 2 Previous Next
Actions
Bookmarked By (2)
