clgrandberry
Illustrator CC Crashes when saving Symbols
Nov 18, 2013 3:33 PM
Tags: #illustrator #crash #library #symbols #cc
My issue is when I open an .eps, (any .eps because I tried it with a multitude of files), and I try to drag a path into the symbols panel then "save symbol library" Illustrator immediately crashes. It doesn't matter if its just one symbol or multiple symbols.
This is the problem details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Illustrator.exe
Application Version: 17.0.0.260
Application Timestamp: 528213c9
Fault Module Name: icuuc40.dll
Fault Module Version: 4.0.0.0
Fault Module Timestamp: 4ec34328
Exception Code: c0000005
Exception Offset: 000000000007e2c4
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: d234
Additional Information 2: d234ddd23bcf6dc7ea70c3a41da38446
Additional Information 3: d051
Additional Information 4: d051bd7d4d07cec3ec3f832502701c2d
I recently downloaded Illustrator CC,
I do not have a prior version of Illustrator on my computer.
HPPavillion HPE
Windows 7 Home Premium
Intel Core i5
6GB Ram
64 Bit
I use a Drawing Tablet not a mouse
Your help in this is GREATLY appreciated!!!
    Nov 19, 2013 2:05 AM   in reply to clgrandberry
    You didn't mention where those EPS originally came from. Since EPS is an exchange format (and a very old one on top of it), those EPS can come from practically anywhere and may have been created any time since the invention of desktop publishing.
    So those files may very well be corrupt or at least not stable. Copying elements from one file to a new one is a valid way of solving corrupt files (and you can be glad that it helped since the file might also have been corrupt beyond repair).
    Nov 19, 2013 4:50 AM   in reply to clgrandberry
    Did you try and save a brushes library? Or just  create brushes?
    When you save a library, you create a new file on your computer. Check if permissions for the folder are set up appropriately. And check the disk. Maybe it happened when saving the file.
    Nov 19, 2013 9:39 PM   in reply to clgrandberry
    Hi Clgrandberry,
    Thanks for reporting this issue. I am able to reproduce this issue at my end. I am forwarding this bug to Illustrator team.
    With Best Regards,
    Mohit Gupta.
