Animatetrunks
I can't create contact sheet with Photoshop CC
Nov 18, 2013 6:18 PM
Tags: #photoshop #cloud #cc #contact_sheets
I have a problem,
Since I have installed Adobe Photoshop CC, I have never been able to use the option Contact Sheet II
Here the error message that I get when I use the option
Please help me
  • JJMack
    Jan 9, 2006
    Nov 18, 2013 9:08 PM   in reply to Animatetrunks
    When do you get the error?  Do you get the contactsheet II dialog fill it in and run? Do you see this in CC the line numbers shown in you screen capture seem to line up with what I see on CC contactsheetII script.
    do you get this?
    Nov 19, 2013 5:14 PM   in reply to Animatetrunks
    It trying from Bridge make sure there are check marks for at least bridge and photoshop in edit/preferences/startup scripts.
    Nov 21, 2013 11:32 AM   in reply to Animatetrunks
    Google Translate works well.
    Nov 21, 2013 2:11 PM   in reply to Animatetrunks
    Can I get this log file from your system?
    C:\Users\<your username>\AppData\Roaming\ContactSheetII.log
    ~\AppData\Roaming\ContactSheetII.log
    Nov 25, 2013 10:31 AM   in reply to Animatetrunks
    I've got same problem on windows 8. Last time I use ContactSheet on 14th november, it worked. But now I've got exactly same issue as Animatetrunks.
    Animatetrunks can you tell me if new installation in English have solve this issue?
    Is there anyone can help?
    Nov 25, 2013 11:09 AM   in reply to Animatetrunks
    I found!!!
    Trash file name PHXS_14_1_1_fr_CA.cache
    in this path:  C:\Users\<your username>\AppData\Roaming\Adobe\CEPServiceManager4\cache\ExtensionManifest\
    Nov 28, 2013 8:29 AM   in reply to Animatetrunks
    Same problem here, im on Macbook Pro with Mavericks
    Dec 16, 2013 12:23 PM   in reply to Lipovskoy
    Hello,
    I have the same problem on my Imac i5 2,5Ghz 10.7.5
    Here is my error Message:
    File: /Applications/Adobe CC/Adobe Photoshop CC/Presets/Scripts/ContactSheetII.jsx
       Line: 9572
       Error Name: TypeError
       Error Number: 21
       Line: (9563)            un.value = 1;
       Line: (9564)          } else {
       Line: (9565)            un.value = Math.round(un.value);
       Line: (9566)          }
       Line: (9567)        }
       Line: (9568)
       Line: (9569)        return un;
       Line: (9570)
       Line: (9571)      } else {
       Line: (9572) >>     return Number(f.toFixed(3));
       Line: (9573)      }
       Line: (9574)    };
       Line: (9575)
       Line: (9576)    //
       Line: (9577)    // Function: updateUnitWidget
       Line: (9578)    // Description: Set the value of a numeric UI field
       Line: (9579)    // Input:  obj - UI widget
       Line: (9580)    //         type - UnitValue type
       Line: (9581)    //         base - the resolution base (opt)
       Line: (9582)    // Return: number or UnitValue
    [ContactSheetII.jsx]
    main()
    _main()
    execCSII_UI([Object:[object Object]])
    exceptionMessage([Error:Typfehler: undefined ist kein Objekt])
    Dec 25, 2013 4:52 AM   in reply to oliver378
    Same here
    I'm on a Mac Pro and the problem started a while back with Photoshop CS6 on OSX 10.6.8. I updated to OSX 10.9.1 but contact sheet still won't work (same error message as oliver 378 posted).
    So this is clearly no OS problem. Please Adobe, fix this!
