Fluid Grid Templates with Responsive Images & Change Color Code back to the default.
Nov 18, 2013 6:03 PM
Tags: #help #template
I've made a Template from a Fluid Grid Layout(CS6) and can only get the images to be responsive if I make the images all the same height and width. What's up with that?
All Desktop layouts stay consintent with images that are (800w x 800h) and this one that is 1173w x 800h.
Suddenly this 1173w x 800h is inconsitent in the Tablet layout. Here the page shifts to a much smaller height - moving the logo, nav, footer etc up to a shorter layout and then back to the normal Tablet layout size once it links onward to the pages relevant to that square 800 image. I tried the problem image at 800w x 545h and it caused the same problem.
Also, I changed the color code and can't get it back to the default.
    Nov 19, 2013 3:57 PM   in reply to ACILL
    By default, FGLayouts apply a max-width of 100% to all <img>tags.  Basically, this allows those elements to scale in proportion to the container size -- up to the image's native file size. This only works if you don't add any height or width attributes to your HTML code.  Doing so will defeat the CSS.
    Nancy O.
    Nov 19, 2013 4:31 PM   in reply to ACILL
    I guess I really don't understand your question then.  Can you provide a link to your online page so we can see what you mean?
    Nancy O.
    Nov 20, 2013 8:30 AM   in reply to ACILL
    You might want to validate code and fix your errors.
    http://validator.w3.org/
    Nancy O.
    Nov 21, 2013 9:09 AM   in reply to ACILL
    When you upload your work to a remote server and provide a link, I'll take another look.  Without seeing it in a browser, it's impossible to trouble shoot what might be going on.
    Nancy O.
