Stuck at publishing for andriod 4.3
Nov 18, 2013 11:56 PM
I get stucked when i tried to publish air for android 4.3 using flash cs6. No issue with android 4.1.2.
    Nov 20, 2013 8:07 AM   in reply to ZJ
    Can you elaborate on what you mean by publishing for 4.3? Are you trying to set something like android:minSdkVersion="4.3" or are you saying your APK does not work on 4.3 (are you on a Nexus?) but it does work back in 4.1.2 (what I still use on SGS)?
    Nov 21, 2013 6:42 AM   in reply to ZJ
    I have quite a few issues in both Flash and Flash Builder with MTP devices. I know it's not convenient but uncheck "Install application on the connected Android device", produce the APK, then copy it over using your standard filesystem. You should have an app called something like "My Files". Open it, choose "All Files" and your APK will be where you put it. Click to install it.
    I have a Samsung Galaxy S3 (4.1.2) that works perfectly device testing over USB and with installs. I have a Samsung Galaxy Tab 3 8.0" running 4.2.2 that refuses to let me USB debug and will hang if I leave that option checked. I installed all device drivers I could find, absolutely everything. ADB tells me the device is stuck on "authorizing" which means when you toggle USB Debugging it should get a RSA cert from the PC and ask you if it's ok to debug with the connected computer. On my device this dialog never came up, ever, after toggling it a million times. 'adb devices' continues to show me the device listed as 'unauthorized'.
    I gave up and I just test on other devices (Sony Xperia Tablet Z works perfect, so does SGT 2 7.0", so does my phone, ASUS Transformer, etc etc). I've found a huge amount of issues integrating Samsungs 4.2.2 and up devices.
    Nov 22, 2013 2:02 AM   in reply to ZJ
    Can you please let me know, if you are using Flash Professional CS6 or Flash Professional CC. Also, please let me know the version of the Flash professional that you are using.
    Regards,
    Veena
    Nov 22, 2013 6:41 AM   in reply to ZJ
    I was having this issue but I unchecked install and I install it by copying the apk to my SD Card and run the apk intaller.
    Nov 25, 2013 5:06 AM   in reply to ZJ
    Please try with Flash Professional CC, you should not see this issue.
    Nov 25, 2013 8:36 AM   in reply to Veena S
    The issue has to do with the devices status to adb than the version of Flash used. At most Flash may realize the install of AIR or the copy process is failing while it handles that situation but the real issue at hand is the device itself isn't allowing the user to specify the computer it's attached to is "authorized" to install content on it.
    This is really only for a small set of devices but it's becoming increasingly noticable that 4.2.2 and up devices are currently affected by it. I'm sure a driver or firmware update will resolve this in the near future.
    Copying the APK manually isn't too hard over MTP.
