cheenho
I have a file with 9 artboards but when I open it up I can only see one
Nov 19, 2013 3:57 AM
Help T_T
    Nov 19, 2013 4:11 AM   in reply to cheenho
    Maybe it's a version conflict.
    But you can try to use this shortcut to view all the artboards:
    cmd+opt+0 on mac
    or
    alt+ctrl+0 on windows.
    Hope it helps!
    Nov 19, 2013 7:19 AM   in reply to cheenho
    cheenho,
    If you see only one, you have to also describe what makes you think there is more.
    Nov 19, 2013 9:23 AM   in reply to cheenho
    Which version of Illustrator are you using?
    And which version of Illustrator are you using at home?
    What file format(s) are you choosing? If it is .ai, what AI version exactly?
    Nov 19, 2013 10:35 AM   in reply to cheenho
    when you choose Window > Artboards, what do you see at work and home when using the same file?
    Nov 19, 2013 6:33 PM   in reply to cheenho
    Sounds like something is corrupted. My advise: at school create a simple new document with multiple artboards and check if you can see them at home. If you get the same problem, you may have corrupted preferences which will require resetting the preferences. If there is no problem with the new file this means only the original file is corrupted which will require to copy its content, paste it in the new document and recreate the artboards.
