Cheryl Dwyer
How do I install the Adobe PDF Creation Add-On printer instance in FM11?
Nov 19, 2013 9:09 AM
Tags: #save_as_pdf #framemaker11
How do I install the Adobe PDF Creation Add-On printer instance in FM11? I don't recall NOT installing it, but I can't save any FM doc as a PDF. Unfortunately, the Help guide simply tells me not to delete the Adobe PDF Creation Add-On printer instance plug-in, which isn't very helpful at this point.
Thanks.
    Nov 19, 2013 9:13 AM   in reply to Cheryl Dwyer
    If you’re running the standalone version of FM, then the “headless” Acrobat comes with it; reinstall FM to repair that part. However, if you already had a full version of Acrobat installed, the FM installer may have screwed it up – you’ll have to uninstall all Acrobat(s) and reinstall.
    Nov 19, 2013 9:47 AM   in reply to Cheryl Dwyer
    If CS6 had the full Acrobat in it, you should be able to uninstall Acrobat, then use the install disk to just reinstall Acrobat again.
