adding a Flex Component via actionscript
Nov 19, 2013 10:38 AM
I have a Flex Project that is set to use both MX+ Spark.
The project is almost entirely built in AS3 but I would like to use a couple of Flex components.
In an ActionScript Class, how does one add a Flex Component such as DateSpinner?
I have included the spark.swc in the build path.
I am using Flash Builder 4.7.
This is intended to be used as a Desktop app.
    Nov 19, 2013 10:47 AM   in reply to DachFlach
    It should be as easy as instantiating the class ( and adding it to a container). Just look up the class documentation and have a go.
    http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/spa rk/components/DateSpinner.html#DateSpinner%28%29
    Nov 19, 2013 11:33 AM   in reply to DachFlach
    OK, this is outside my experience.
    I don't think you can mix Flex components directly with Flash UI components - think you may need to use UIMovieClip.
    Nov 19, 2013 11:51 AM   in reply to DachFlach
    Why are you using MovieClips in a Flex project?
    Nov 19, 2013 12:02 PM   in reply to DachFlach
    Why use a MovieClip for your class rather than a Flex container?
    Nov 19, 2013 12:11 PM   in reply to DachFlach
    Ideally if you have a project using Flex, you should use Flex components, so your class should be subclassing a Flex container, not a MovieClip (unless there's a specific reason for using a MovieClip ).
    I really don't have enough spare time to do anything but give you a nod in the right direction.
