How to send datas properly to Google Analytics (ANE-Google-Analytics)
Nov 20, 2013 2:41 AM
Tags: #ane #googleanalytics
Hello,
I meet a problem when I'm using the native extension created by Alessandro Bianco : ANE-Google-Analytics. I tested this code many times, in the context of AIR mobile application, but I tested it without any success to add new datas to Google Analytic history. I'm really connected to internet properly.
Moreover I think that I've made my functions as required by the author : Can you look at my code below to detect some errors to communicate with Google Analytics ?
<s:TabbedViewNavigatorApplication
    xmlns:fx="http://ns.adobe.com/mxml/2009"
    creationComplete="creationCompleteHandler(event)"
    import eu.alebianco.air.extensions.analytics.Analytics;
    import eu.alebianco.air.extensions.analytics.api.ITracker;
    import flash.utils.clearInterval;
    import flash.utils.setInterval;
    import flash.utils.setTimeout;
    public var ganalytics:Analytics;
    public var gtracker:ITracker;
    protected var i:int = 1; // Debug
    protected static const ANALYTICS_ID = "My UA code is here";
    protected function creationCompleteHandler(event:Event):void
        // I launch the tracker :
        ganalytics  = Analytics.getInstance();
        ganalytics.dispatchInterval = 5; // Interval for connecting : 5 seconds
        // I begin to use the tracker :
        GtrackerSessionUsing("RecordingView","HomeView",true);
     * GtrackerConnecting
     * @description : Open connection to Google Analytics, and create instance for a tracker
     * @argument : actionName = "RecordView" or "RecordEvent"
     * @argument : valueName = Name of the view or name of the event to record
    public function GtrackerSessionUsing(actionName:String, valueName:String, createConnection:Boolean=false):void
        gtracker = ganalytics.getTracker(ANALYTICS_ID);
        gtracker.startNewSession();
        if(etablirConnexion==true)
            // Tracking des views :
            var compteur:int = 0;
            var intervalGtrackerCnxOuvrir:uint = setInterval(function():void{
                counter++;
                trace("gtracker ="+gtracker);
                if(counter==50){ // Try to connect - only - 50 times
                    trace("GoogleTracker fails to connect !");
                    clearInterval(intervalGtrackerCnxOuvrir);
                else if(gtracker!=null){
                    trace("GoogleTracker success to connect !");
                    GTrackerRecordAction("EnregistrerView","HomeView");
                else{
                    trace("Trying to connect to GoogleTracker... (itérate #"+counter+")");
            },5000); // All 10 seconds : iterate a new connection test
    protected function GTrackerRecordAction(actionName:String, valueName:String)
     * @description : Use the tracker of the Google Analytics connected account, all of Views can call this function with this model of code: parentApplication.GTrackerRecordAction(...)
        if(gtracker!=null)
            switch(actionName){
                case "RecordView":
                trace("GoogleTracker : gtracker.buildView("+valueName+").track()");
                gtracker.buildView(valueName).track();
                break;
                case "RecordEvent":
                switch(valueName){
                    case "event1":
                        gtracker.buildEvent("click", "button").withLabel("play").withValue(10).track();
                    break;
                    case "event2":
                        gtracker.buildEvent("click", "button").withLabel("stop").track();
                    break;
                    case "event3":
                        gtracker.buildEvent("app", "quit").track();
                    break;
                break;
Best regards.
    Dec 11, 2013 8:33 AM   in reply to Youtch
    you can check this out  ! http://www.devactionscript.com/free-ane/google-analytics-ane-adobe-air -native-extensions-for-android/
    it is based on Google Analytics SDK v3 . I hope it works for you
    Mar 7, 2014 11:18 AM   in reply to Youtch
    Youtch,
         I'm not sure exactly what your issue is, but I was unable to connect and looked at your code, modifying it for my purposes and it fixed my code. Hopefully it can help fix yours.
         I did notice one thing as I went through, however:
    You use
                    counter++;
    The compteur does not match the counter variable. It appears a problem with Franglais is the issue here.
    In the event it may help, here is the code I used:
    In my creationComplete function:
    GoogleAnalytics.initialize("UA-47303719-1");
    Here is the code in my app.xml
    <extensions>
            <extensionID>eu.alebianco.air.extensions.analytics.NativeGATracker</extensionID>
        </extensions>
    And here is the class I created to use the ANE:
    package ANE.NativeGATracker{
         public class GoogleAnalytics{
              static private var _analytics:Analytics;
              static private var _tracker:ITracker;
              static private var _supported:Boolean;
               * There is no need to instantiate this class
              public function GoogleAnalytics(){
              * Initialize the GoogleAnalytics object.. or return false, if Analytics isn't supported
              static public function initialize(ANALYTICS_ID:String):Boolean{
                   if(Analytics.isSupported()){
                        _analytics  = Analytics.getInstance();
                        _analytics.dispatchInterval  = 5;
                        establishTracker(ANALYTICS_ID);
                        _supported   = true;
                   }else{
                         _supported  = false;
                   return _supported;
              * Establish the tracker connection
              * @description: establishes the tracker connection... reattempt every 10 seconds, up to 50 times
              static private function establishTracker(ANALYTICS_ID:String):void{
                   _tracker  = _analytics.getTracker(ANALYTICS_ID);
                   _tracker.startNewSession();
                   var counter:int    = 0;
                   var establishInterval:uint  = setInterval(function():void{
                        counter++;
                        trace("Google Analytics tracker = " + _tracker);
                        if(_tracker != null){
                             trace("GoogleAnalytics tracker connected!");
                             _tracker.buildView("Launch").track();
                             _tracker.buildView("Home").track();
                             clearInterval(establishInterval);
                       }else if(counter == 50){
                             trace("GoogleAnalytics failed to connect.");
                       }else{
                             trace("Trying to connect to Google Analytics... attempt #" + counter);
                   }, 5000);
             * Analytics object
              static public function get analytics():Analytics{
                   return GoogleAnalytics._analytics;
              * Tracker object
              static public function get tracker():ITracker{
                   return GoogleAnalytics._tracker;
              * Returns true if analytics are supported, but false if they are not. Check this before any use of the tracker or analytics objects
              static public function get supported():Boolean{
                   return GoogleAnalytics._supported;
