Multiple record data merge into paragraph styles-applies the wrong style
Nov 22, 2013 12:14 PM
Tags: #merge #styles #cs6
Hi, I've been working on this project for sometime and everytime I manage to get one part of the workflow to work another seems to break. My agency publishes catalogs in multiple formats: large-print, audio, braille, and HTML. I've been trying to redesing our work process so that the catalogs will be laid out from merged data out of comma-separated file. The data merges have worked fairly well in Word, but InDesign is a challenge. I'm merging multiple records on a page, like a mailing label. The paragraphs need to be formatted and I'm trying to apply a paragraph style to them. After much work, I think I've finally got the data merge to work correctly, but the wrong paragraph styles are applied. I'm going to apply a new master page to the data once the data is merge that uses the paragraph styles for text variable running headers and I need to build a table of contents based on the paragraph styles so I need this to work. Attached are some screenshots.
Master page set up for data merge with paragraph styles:
Here is the merged document with the wrong paragraph styles applied:
I have only a few weeks to get this process ironed out to keep to our rigorous production schedule. If anyone can help I would really appreciate it.
thanks,
Lina
Replies 1 2 3 ... 5 Previous Next
    Nov 22, 2013 12:36 PM   in reply to LinaD36
    Can't really tell from those screen shots what styles are applied to the placeholders....
    Nov 22, 2013 2:10 PM   in reply to LinaD36
    Lina,
    Would you paste two records, one with all info and one without, into a post? Saves making stuff up (I'm lazy).
    Nov 22, 2013 3:14 PM   in reply to LinaD36
    Comparing the paste of data to the screen shots...man, there's a lot of pieces in individual fields. It is gonna take a little bit to reconstruct a spreadsheet.
    Nov 23, 2013 4:22 AM   in reply to LinaD36
    I know you have the CSV...but if I want to replicate what you are doing to help, I have to remake the spreadsheet from the merge data as presented in the thread. Easier if the data in the thread was from the spreadsheet rather than post merge.
    Nov 23, 2013 5:36 AM   in reply to LinaD36
    I am sending you a Private Message with a download link to a sample. Please respond in this thread as to whether it helps you or where it is going wrong.
    I was up for almost 24 hours and hit the hay early last night. I think I might have seen what I think is a problem last night if I hadn't been so tired.
    You are tagging the merge fields. Out of curisoity, why?
    The ZIP file I have linked to in a PM has an ID CS6 file and IDML (don't know what version for sure you are using), the tab delimited merge I used, and the Excel file. Likely I got fields wrong/misplaced going from the pasted data to a spreadsheet.
    Mike
    Nov 23, 2013 2:16 PM   in reply to LinaD36
    Lina--did you check your PM and download, look at the sample file I provided? All is in parahraph styles with the exception of the character style used in the line:
    DB73147 11 hours1 minutes
    The hours/minutes text is the character style. You do not need to use Tagging. Just style the merge fields with the paragraph styles.
    Mike
    I'm not going to put words in Mikes mouth, but I think he was aking why there are what look like XML tags around all the text strings in the merged file.
    I suspect, too, that the problem may be that when you start out with null fields and remove blank lines you are essetnially shifting the following lines into the first paragraph.
    Nov 23, 2013 2:24 PM   in reply to Peter Spier
    Putting words in my mouth is better than the other day when I put my foot into it...
    Lina,  I do think it is the tagging and assigning paragraph styles to both the fields and tags that is fouling things up. Do take a look at the sample file. It will work fine for you to create it as per the sample.
    Mike
    Nov 23, 2013 2:25 PM   in reply to Peter Spier
    Well I just ran a basic test to see if that's true, and it isn't, so now I'm back to wonderaing if you've really formatted things correctly. From waht you've shown us there's no way to see what paragraph styles are assigned to the placeholders. The easiest way might be to select the placeholder frame in the template, then switch to Story Editor view. Show us a screen shot of the story editor.
    Nov 23, 2013 9:05 PM   in reply to LinaD36
    Lina,
    Do check the tags panel. The reason is because those colored brackets that can be seen in your screen shot are tag brackets used for mapping styles to XML nodes.
    No worries. We'll figure it out together on Monday. Have a restful remainder of the weekend.
    Nov 25, 2013 9:25 AM   in reply to LinaD36
    In my testing here it didn't do that (though that was what I surmised was happening to you back in post 14), so I think it should not be happening, but the XML tags are somehow getting in the way.
    Mike is knowledgable in XML, and I am not, so lets wait and see what he has to say.
    Nov 25, 2013 10:14 AM   in reply to LinaD36
    I don't remember this happening in past versions. But I mainly use XML. And a quicky test converting your file to XML worked fine (and besides, it ends up all in continuous text frames...).
    I don't do much GREP. But you can do this via a Find/Replace.
    First, in your main document, you can delete the tags--but do this on a second copy of your working file!
    Change your Content Placement options to not remove blank lines (these are in the Datamerge panel).
    Then after the merge, change the format of the two blank lines at the beginning of the records without the two lines of data:
    Note the Change Format style is changing those two paragraphs to Title.
    Then rerun the find to remove the two blank paragraphs.
    I suspect this can be done easier. I am sitting awaiting an appointment and cannot go much further than this for now, sorry.
    Nov 25, 2013 10:28 AM   in reply to MW Design
    If you don't remove blank lines from the merge, I think all that's necessary is to remove blank paragraphs. No need to mess around with changing any formatting.
    You can do that by GREP using Find ^\r and leave the change field blank. That looks for a paragraph return as the first character in the paragraph.
    Using Find ^\s*\r will also find paragraphs with nothing but blank space in them, or multiple empties as a single block (\s also includes \r as a match).
    Nov 25, 2013 10:54 AM   in reply to Peter Spier
    Hey, first time I successfully logged in using my phone since the reset...
    Peter, removing the blank lines alone has the title line and style change to the genre style with local formatting. I don't have access to 5.5 or earlier with my laptop so I cannot try in previous versions until tonight.
    Is there a means to search for the locally styled genre style and change it to the title style?
    Nov 25, 2013 11:16 AM   in reply to MW Design
    Mike,
    IF each paragraph has the correct style applied (and at this point that may be a big IF, since it may be the XML tags overriding the styles),
    AND the blank lines are not removed during the merge,
    THEN the Find/Change operation with the queries I posted above should not be changing any assigned paragraph styles in the merged document, so if the Title line had the Title style applied before Find/Change, it will have it after as well.
    Your previous files that you sent to me did not use discreet styles the same way they are arranged in the screen cap of the story editor, and that might be part of the problem.
    Going out for awhile, but I should be back in a few hours.
    Nov 25, 2013 12:03 PM   in reply to Peter Spier
    Looking forward to your return...
    Merge file...
    After merge, before removal of blank paragraphs...
    After removal of blank paragraphs using ^\r (and other F/R methods)...
    This was using 5.5, same result in CS6.
    Nov 25, 2013 2:21 PM   in reply to LinaD36
    LinaD36 wrote:
    Peter, I also had another question for you related to apply a new Master page to these pages, once the data is correct. Is there a way to apply the new master so that it doesn't apply a new default text box on top of the existing text box that's there?
    Just don't use a master page that has a text frame on it where you don't want on.
    Nov 25, 2013 2:34 PM   in reply to MW Design
    Mike,
    That sure isn't what I see here...
    Here's a .csv file I made to test concatenation with commas inthe fields, along with a merge template, and a somewhat edited merged doc (with blank lines and some style changes inthe first frame, but you can play any way you like): https://www.yousendit.com/download/OGhjYUp3aFJiV3pIRHRVag
    Whe I run either of the queries from above I end up with the correct styles. Are you sure you cleared the change formatting? It should be empty, as should the find formatting.
    Nov 25, 2013 2:54 PM   in reply to LinaD36
    There wouldn't be one, by default, on any master other than the first one (master A) or a copy of Master A, or another "based on" Master A, and then only if you asked for one during document setup, or added it later yourself. You should be able to open any master page by double-clicking it in the Pages panel, and then you can select and delete anything you like, or add anything new you might need.
    Nov 25, 2013 3:03 PM   in reply to LinaD36
    Yes, Please. Very Much.
    Nov 25, 2013 3:46 PM   in reply to LinaD36
    Yep, me too. Thanks.
    Nov 26, 2013 2:28 PM   in reply to LinaD36
    Sorry, been out all afternoon, but I've been playing with your file, and I'm now totally perplexed. I get the same change as you in your file, and now I'm getting it with my file as well, and I swer that didn't happen yesterday, honest.
    Nov 26, 2013 2:43 PM   in reply to Peter Spier
    I think this is probably expected behavior. and I need to ponder this for a bit to see if I can think of a way to fool ID into behaving differently. Maybe I can get Peter Kahrel or Jongware to join us.
    Nov 26, 2013 4:03 PM   in reply to Peter Spier
    I heard back from Jongware who said he couldn't get the GREP to fail, but he doesn't have any experince with Data Merge, and that got me to thinking again about what I'd done yesterday. I applied the styles after the merge from a template designed for a different test. I just tried again with a text frame that had not had any connection to a data merge, and it works correctly, so it seems ther's something about the data merge itself that screws things up. I smell a bug, or maybe "feature."
    Just checked, and the problem is the find change behaves exactly the same as the remove blank lines -- it doesn't delete the field markers, and they have the styles attached.
Actions
Bookmarked By (1)
