My background flickers when exporting mpeg2
Nov 24, 2013 6:29 PM
I had to have help figuring this out in elements now I am having trouble with pro. My background is my bookcase and I am having trouble with the books being jittery when exporting. In elements I was able to overcome this by selecting HDTV 1080p 29.7 high quality and then changing the settings to 720x 480. A 5min video will export in like 3 min and be about 400 meg. I tried using these same settings in pro and it doubled the file size took about 12 min and still my books we jittery and the text in my tittles were not real clear. I have tried changing the vbr to 2 passes, selecting render at maximum depth, use maximum render quality and use frame. Lending. I have tried. H.264, mpg2 to DVD, and even avi but I cannot get anywhere close to a 400 meg file or get rid of the jittering of my books in the background. Any ideas?
    Nov 24, 2013 7:04 PM   in reply to xrcrc453
    What is your source footage?
    Nov 24, 2013 7:20 PM   in reply to xrcrc453
    Show us the Export Setting Window  details - screen grabs.
    Can you "Snip" it?
    Nov 24, 2013 8:11 PM   in reply to xrcrc453
    Edit your footage in a Matching Sequnce. eg HD 1080 x 1920
    Let the encoder do the export to the spec you require for delivery.
    Nov 24, 2013 8:42 PM   in reply to xrcrc453
    Yes to first question.
    Create a new HD sequence and copy and paste across your edit.
    How did you make the HD fit the SdDsequence?  Well dont do that..OK.  It needs to fit.
    IN Latest CC version 7.1... you maybe able to just change the sequnce setting.
    You need to workout your SD centre extraction for Safe areas. Its no big deal.
    Do you deliver FHA? Full height anamorphic SD?
    Nov 24, 2013 9:08 PM   in reply to xrcrc453
    Do a test..but basic editing wisdom is to edit what you shot and export to deliverable.
    You are down rezzing and scaling on the fly
    Nov 25, 2013 4:36 AM   in reply to xrcrc453
    Is your origional footage interlaced? It might be TFF and you are putting it in to a BFF NTSC sequence and then deinterlacing on the export. This might cause you flickering problems.
