1mikediaz
What are the right sequence setting for HD Widescreen Video?
Nov 26, 2013 9:51 AM
Tags: #widescreen_framing
Hey Everyone,
When I started my project I noticed when I transferred my file to the timeline it created black borders. I saw a few videos online about choosing the right sequence settings. Well, I shoot with the same settings on my DSLR's and just wanted to know if you had any tips on matching the sequence settings for my desired films. I can surely adjust my DSLR settings so it can save me a headache in the post production. All of my projects will be HD Widescreen Videos. Can anyone help me out?
Note:My DSLR settings are MPEG movie, 1920x1080, 23.976 Frame Rate, Pixel Aspect Ratio 1.0
Michael
    Nov 26, 2013 9:56 AM   in reply to 1mikediaz
    If you are using premier pro CS6 or CC , Just right click on the clip in the project assest Tab and click on the option "New Sequence From Clip".
    It will automatically chose the best setting for your clip.
    Regards
    Karandeep singh
    Nov 26, 2013 10:32 AM   in reply to 1mikediaz
    Just do as suggested above.
    Nov 26, 2013 10:37 AM   in reply to 1mikediaz
    Widescreen is in DV , so the frame size is 720*480 , whereas the clip setting you have is 1920*1080 . So sequence setting will not match the clip setting and that Might give you problem.
    regards
    karandeep singh
    Nov 26, 2013 10:52 AM   in reply to 1mikediaz
    HI,
    The first screen you get is of setting the sequence setting .
    According to the clip setting just select the below sequence setting.
    Digital SLR->1080P->DSLR1080p 24.
    Nov 26, 2013 10:56 AM   in reply to 1mikediaz
    Right click the clip in the bin and choose New Sequence from Clip.
    On a side note, all HD is widescreen (16:9).  There are no 4:3 HD formats.
    Nov 26, 2013 11:04 AM   in reply to 1mikediaz
    HI,
    As you told that you are new user of premier pro . Below is the document that might can help you in knowing how to st up the sequence.
    http://help.adobe.com/en_US/premierepro/cs/using/WS3E67AF4C-B2A2-4f04- 90B4-F8CCFB74B144.html
    Nov 26, 2013 11:26 AM   in reply to 1mikediaz
    Quickest way to set up a sequence that matches the footage:
    file
    Get Started with Premiere Pro
    New to Premiere Pro? Get started with your first project — editing a video. In less than an hour, you'll learn to edit together different types of media to tell a video story.
    Nov 26, 2013 12:40 PM   in reply to 1mikediaz
    Your second problem could very easily be the result of the first.  Implement the solution and check things over.
