ddraudt
Font Issue with After Effects CC
Nov 26, 2013 3:08 PM
I am running After Effects CC (on Mavericks).
After creating an animation using fonts from Typekit, I now am having trouble where the fonts flicker back and forth between two different ones during the animation. At first, I thought I accidentally did something with animating it, but after deleting that type layer, creating a new layer, saving, exiting and returning, I now have the same issue.
The last time after rendering a video, these error messages popped up:
after effects problem invalid glyph ID (83::2)
After Effects warning: Unknown Exception
So I force quit the program. When restarting it, the error message below shows:
These are the fonts that have trouble. It looks like it is flickering between ProximaNova bold and regular. What is causing this and how can I fix it?
Lately I've had trouble syncing to the cloud.
    Nov 26, 2013 4:20 PM   in reply to ddraudt
    There's a bug in the global performance cache related to font substitution: If you load a project with a missing font, After Effects will substitute a placeholder font. If you then install the missing font, After Effects may not update cached image information with the new font. So, if you install a font after loading a project for which that font was reported as missing, purge the cache (Edit > Purge) to force the cached image information to be updated with the new font.
    Dec 4, 2013 3:39 AM   in reply to ddraudt
    having the same problem... to purge the chache didn't solve my problem - still flickering
    even if i don't get the error message on startup and the fonts schould've been loaded correctly
