Side Heads - Cannot change size
Nov 27, 2013 5:29 AM
Tags: #size #page_layout #framemaker_11 #column_layout #side_heads
Hello ,
W7, FM11.
I think I might be doing something fundementally wrong, but I cannot change the size of a Side Head.
I have already populated the document and can add a Side Head by Format > Page Layout > Column Layout... and checking Room for Side Heads.
However, no matter what I change Width to, it always remains the same size.
What am I doing wrong?
    Nov 27, 2013 7:08 AM   in reply to bowen192
    > ... cannot turn a Side Head on and off in the body of a document which uses the same master page?
    I never use SH, but just playing with it a bit, it behaves, umm, unexpectedly.
    I would have suggested creating MPs "Left.SH" and "Right.SH" which would be used via Apply Master Pages whenever a paragraph of tag, say, "Sidehead" was used. Doesn't work.
    Conversely, allowing Left/Right to be SH layouts, and creating Left.Normal and Right.Normal pages, to be AMP-mapped by paratags with, say, ".norm" names, doesn't work either.
    What does work is letting all the pages be SH, and creating paragraph formats of name ".ash":
    Paragraph Designer > Tag [ Body.ash ]
    Properties: Pagination
    [*] Across all Columns and Side Head
    (as long as you don't need multi-column)
    Nov 27, 2013 7:48 AM   in reply to bowen192
    Sideheads are a document level property. They are either turned on or off for the flows in the document. You can adjust the individual widths on different Master pages, but all Masters must have them. To turn them on/off on individual pages, you have to accomplish this by applying appropriate paratags that are set to be formatted "Across all Columns and Sideheads" or break up the file into smaller files and apply the property accordingly (using the Book to keep things together visually).
    That being said, when you change the sidhead width (or any other property) via the Column Layout, it changes only the default Left/Right masters. Any other master pages that you may have created, need to be manually tweaked.
