Indesign Server CC Trial issues
Dec 3, 2013 5:48 PM
Tags: #indesign_server #cc #svml_dispmd.dll
The installation instructions states
You need to download Adobe Provisioning Toolkit Enterprise Edition (APTEE) for using the InDesign Server trial
The download link only refers to CS6, CS5.5 & CS5 not CC
Since there is no Adobe Provisioning Toolkit Enterprise Edition for CC I decided just to install and run the trial.
However I got the Adobe InDesign Server is not properly licensed and will now quit message.
According to the CC Release notes it says:
InDesign CC Server needs to be activated before it can be used. If the computer is online, activation is done automatically when you install. You need to provide your Adobe ID, and serial number when prompted by the installer. Unless the software is activated, you'll see an error, "Adobe InDesign Server’ is not properly licensed and will now quit."
My computer was online yet the it seems it didn't perfom the automatic activation as it suggests. When I entered my AdobeID credentials I did not get any errors saying it could not connect online.
So I had to do something and decided to use the Adobe Provisioning Toolkit Enterprise Edition for CS6.
This allowed me to get pass the licensing issue.
The next problem was I was getting DDE Server Window:InDesignServer.exe System Error popup. Telling me The program can't start because svml_dispmd.dll is missing from your computer.
C:\Program Files\Adobe\Adobe InDesign CC Server x64>indesignserver
.  InDesign CC Server Version 9.0 x64 Evaluation
.  Copyright 1999-2013 Adobe Systems Incorporated and its licensors.
.  All rights reserved. See the other legal notices in the ReadMe.
11/28/13 08:08:49 INFO  [server] Initializing
11/28/13 08:08:49 INFO  [server] Loading the application
11/28/13 08:08:49 INFO  [server] Scanning for plug-ins
11/28/13 08:08:49 INFO  [server] Registering 113 plug-ins
11/28/13 08:08:53 INFO  [server] Completing Object Model
11/28/13 08:08:53 INFO  [server] Saving Object Model
11/28/13 08:08:53 INFO  [server] Initializing plug-ins
11/28/13 08:08:53 INFO  [server] Calling Early Initializers
11/28/13 08:08:53 INFO  [server] Starting up Service Registry
11/28/13 08:09:02 INFO  [server] Executing startup services
11/28/13 08:09:02 INFO  [server] Using configuration configuration_noport
11/28/13 08:09:02 INFO  [server] Initializing Application
11/28/13 08:09:02 INFO  [server] Completing Initialization
11/28/13 08:09:02 INFO  [server] Calling Late Initializers
11/28/13 08:09:08 INFO  [server] Image previews are off
11/28/13 08:09:08 INFO  [server] Server Running
11/28/13 08:09:08 INFO  [javascript] Executing File: C:\Program Files\Adobe\Adobe InDesign CC Server x64\Scripts\startup scripts\ConnectInstancesToESTK.js
11/28/13 08:09:08 INFO  [javascript] Executing File: C:\Program Files\Adobe\Adobe InDesign CC Server x64\Scripts\converturltohyperlink\startup scripts\ConvertURLToHyperlinkMenuItemLoader.jsx
11/28/13 08:09:08 INFO  [javascript] Executing File: C:\Program Files\Adobe\Adobe InDesign CC Server x64\Scripts\converturltohyperlink\ConvertURLToHyperlinkMenuItem.jsxbi n
So after browsing the net to see where I can get this missing svml_dispmd.dll I found this post http://software.intel.com/en-us/forums/topic/285859
and decided to install what it suggested.
I still got the missing dll error so I copied it from C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler into C:\Program Files\Adobe\Adobe InDesign CC Server x64
Now it just sits there and hangs at the same spot
11/28/13 08:09:08 INFO  [javascript] Executing File: C:\Program Files\Adobe\Adobe InDesign CC Server x64\Scripts\converturltohyperlink\ConvertURLToHyperlinkMenuItem.jsxbin
What the heck is going on here?
I have installed Indesign Server CC on another machine and although I did not get the missing dll problem it still however hangs at the same spot mentioned above.
Could someone from Adobe please help. The already I'm losing days with this trial and I will have little days left to test this product.
