Bankhayes
PSE12 Crashes When Creating A Slideshow
Dec 3, 2013 2:57 AM
I've just upgraded to PSE12 and it works fine in most instances. Howver when I try to create a slideshow from a selection of photos it simply stops working and then crashes. Is this a common occurrence?
  • 99jon
    Jan 6, 2010
    Dec 3, 2013 3:31 AM   in reply to Bankhayes
    Are you using high resolution images? If so try re-sizing first and then add the images to the slideshow. If your photo aspect ratio is 3:2 dimensions of 1125 x 750 at 72ppi will usually work well. You can batch process a set of duplicates into a new folder from expert mode:
    File >> Process Multiple Files
