YoshBear
What is the best hard drive configuration for disk/media cache?
Dec 4, 2013 11:23 AM
I just installed a 480 GB PCI SSD for my boot drive. I also have a 240 GB SSD and a 1TB 7200 rpm hd. Can anyone suggest on which drives to place my source files, aep files, media and disk cache and output for the best read/write speed? Thanks for any advice. Same question for Premiere Pro too, if you know!
I'm using a Mac Pro dual proc, 12 core, 40 GB.
    Dec 4, 2013 11:38 AM   in reply to YoshBear
    Hi YoshBear,
    Welcome to Adobe forums,
    We recommend you to go through following link as it provides more information about setting up hardware for Premiere pro and After effects :
    http://forums.adobe.com/thread/878520
    http://helpx.adobe.com/after-effects/using/improve-performance.html
    http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/products /creativesuite/production/cs6/pdfs/adobe-hardware-performance-whitepap er.pdf
    Regards
    Abhishek
    Dec 9, 2013 6:28 AM   in reply to YoshBear
    If you have more than one drive you do not want your cache or source files on the same drive as your applications. The only time I can think of that this would not be the case is when your boot drive is way faster than your other drives and has lots and lots of free space, and I mean way faster. The problem with SSD drives is that they are usually small so they fill up very quickly. It's nice to have the SSD speed but that speed is relatively expensive.
    Since you have an additional SSD drive I'd put my cache files there and my media files on the standard drive. If your system SSD drive is more than 70% full and you didn't have a second SSD drive I would still put cache on the standard drive. The only time I would intentionally opt for putting cache on the system drive is when the system drive is a lot faster than any other drive and there is a lot of free space.
