Ruziyo
Glossary as a Pop-UP
Dec 19, 2007 5:51 AM
Hi Everybody,
As a part of my work, I need to show glossary as pop-up in the robohelp project. Now, I tried with Glossary Hot-Spot wizard in RoboHelp 7.0, but it is expanding the glossary content and its not showing as a pop-up. Pls let me know, if anybody knows how to fix this issue.
Help will be highly appreciated.
Thanks & Regards,
Ruziyo.
    Dec 19, 2007 6:35 AM   in reply to Ruziyo
    Hi Ruziyo
    Sorry, but RoboHelp of any or all versions handles the Glossary as expanding text. Not as popups. If that is the behavior you want, you will need to manually enter all terms and definitions into Text Only popups.
    You should probably advise the development team that you would like to see a choice of how the Glossary Hotspot Wizard creates the terms. You may do that by clicking here and completing the form you will find there.
    Cheers... Rick
    Dec 19, 2007 7:45 AM   in reply to Ruziyo
    Hi again Ruziyo
    I'm posting as my alter ego now.
    If you edit your style sheet (Format > Styles) you will find entries there that control the formatting of Glossary Hotspots and Glossary Text. Change it there and all topics using that style sheet will follow suit accordingly.
    Cheers... Rick
    Dec 20, 2007 5:36 AM   in reply to Ruziyo
    Hi again Ruziyo
    May I ask a super duper silly question?
    You, um, DID recompile your .CHM file after you updated the style sheet, didn't you? Because if you didn't do that step, the changes will not be reflected inside the .CHM.
    Cheers... Rick
    Jul 25, 2013 8:54 AM   in reply to RoboWizard
    Has there been any further development on this functionality?  I'm using RoboHelp 9 and would also like to use pop-up hotspots instead of expanding hotpsots.
    I looked through the RoboHelp 9 Help and the didn't see any options in the Wizard, but wanted to see if anyone had found a workaround.
    Natalie
    Jul 25, 2013 11:45 AM   in reply to natjnelson
    Hi, Natalie
    One of the nice enhancements of RoboHelp 10 is the introduction of a Script called
    Output Generator with Glossary Restyling.jsx
    When you run this script you will see this dialog:
    So, you can choose Popup or Tooltip as alternatives to the expanding hotspot!
    John Daigle
    Adobe Certified RoboHelp and Captivate Instructor
    Evergreen, Colorado
    www.showmethedemo.com
