denniscallan
How to drag video-only from bin to timeline?
Dec 5, 2013 2:42 PM
Tags: #audio #audio_tracks #video_only
I lock the audio tracks and then drag a clip from bin to timeline, but it adds another audio track automatically, which I don't want.  I wish I could just drag from bin to timeline video-only....Can I lock down the audio tracks so no more tracks are added?  I know I can double-click a clip to open in source panel, then drag the video icon, but that is an extra step I would rather not waste time with.
    Dec 5, 2013 3:55 PM   in reply to denniscallan
    If you have no need for audio...Modify the Clips in the Bin  to Audio =None
    Dec 5, 2013 6:15 PM   in reply to denniscallan
    Simplest  way is to bounce it through the Source Monitor.
    Drag> Drop in Source> Drag Video Icon
    Dec 7, 2013 1:35 PM   in reply to shooternz
    You can also accomplish this by unpatching all audio tracks and then dragging clips to the Timeline from either the Project panel or the Source Monitor.
    Dec 28, 2013 1:18 PM   in reply to denniscallan
    It is worked out.
    "VIdeo inserts" would be usually made by editors from the Source Monitor and the workflow is in place for that
    Kind of unusual to video insert an entire clip from the project bin into a time line instead of using In and Out edit points or 3 point edits...or even overlay edits.
    Dec 28, 2013 2:15 PM   in reply to denniscallan
    It's not required to go through the Source Monitor, but I'd agree with Shooter that it is probably the more common work flow.  I think you'd be hard pressed to find a camera op that can get every single shot so perfectly timed that no trimming needs to be done.  In fact, I'd argue it's a poor camera man who even tried to do such a thing.  That kind of fine tuned control belongs squarely with the editor/director, not the camera op/DP.
    When you click on the clip, check for an A+ indicator at the bottom of the audio tracks.  Click that if you see it.
    Dec 28, 2013 2:29 PM   in reply to denniscallan
    I'm using subclips in the bins.  These have already had in and out points defined.
    Ahhh, I did miss that.
    Do look for that A+ though.
    Dec 28, 2013 3:49 PM   in reply to denniscallan
    Well you didnt mention the subclips before I posted in so I had no idea why one would edit from the Bin.
    I will test later today...to see if  subclips can be taken to the sequence from a bin  when the Audio Tracks are not targetted in the timeline.
    I am surprised it doesnt for you but maybe its a bug!.
    Dec 28, 2013 5:49 PM   in reply to denniscallan
    I just tried this in Premiere Pro CC.
    If I take the subclip (with audio) and drag it to the timeline with one of the tracks source patched, then I get video with audio. As expected.
    If I make sure that no audio tracks are source patched, then no matter what I do, I do not get the audio along with the video of the subclip.
    In other words, Mark's way works for me.
    So, perhaps we need to figure out what is different in the setups. Are you on a Mac? Exactly which version of Premiere Pro are you using? Tell us everything you can about your setup and perhaps something will make itself known.
    Edit:  Also, does this happen in a brand new project, or just projects created in older versions? And if you import this project into a new one, does the problem go away?
    Dec 28, 2013 5:52 PM   in reply to Steven L. Gotz
    I tested it too as per Marks screen grab...works for me. eg Un Target A#
    Just as one would expect of it so no bug with subclip video /audio fromthe Bin.
    I can use Drag  or Insert or Over write and they all work.
    Dec 28, 2013 5:58 PM   in reply to shooternz
    It could be a particular type of media, I suppose.
    I used DSLR footage for my test.
    Dec 28, 2013 6:08 PM   in reply to Steven L. Gotz
    I tried AVCHD and Nikon 5d .mov
    Dec 28, 2013 7:22 PM   in reply to denniscallan
    Why are you taking it thru FCP and not editing natively in Premiere? ie Directly.
    What actually is the source footage (pre FCP)?
    Dec 28, 2013 7:40 PM   in reply to shooternz
    Works as expected with XDCAM EX footage as well as good old sd avi files .
    Dec 28, 2013 8:08 PM   in reply to denniscallan
    I ingested to FCP last month because I had not yet started using PP.  Also some footage is older HDV video.  Might have something to do with the issue.  Next time I will ingest directly to Premiere.  But I have hundreds of hours of HD footage, digitzed via FCP, I will be working on.
    As a new  PPRO  user..all that footage is not sub clipped.
    At least you now know...that if subclips are your preferred workflow..it can work as you wish and PPRO can handle "a basic task".
    Dec 28, 2013 10:11 PM   in reply to denniscallan
    a new audio track being created with audio placed there
    Again, look for that A+.  It's telling you that a new audio track will be created for that media, because the tracks available don't match what's needed for the audio.  And that new track is patched by default, so...you get audio.
    Dec 29, 2013 11:02 AM   in reply to Jim Simon
    Looks to me like Jim nailed it. I created a sequence with audio set to 5.1, then in the Project panel I selected a stereo clip. In the Timeline, "A1" was not shown for any of the 5.1 tracks, and the "+" indicator was present. Inserting added a stereo track to the timeline and inserted the clip's audio on that new track. As expected, if I clicked the "+" prior to inserting, the new track was added, with source patching enabled.
    So to avoid having the audio inserted, click the "+" and deselect the new track for source patching. Once you've turned off source patching for one clip with a certain type of audio, the same patching should be applied the next time you select a clip of the same type.
    Dec 29, 2013 5:21 PM   in reply to Jim Simon
    Good catch, Jim.
    It all stands explained.
