cassiel
PDF output does not match Frame TOC
Dec 6, 2013 7:54 AM
My Frame TOC is accurate, the tags are correct.  My PDF output has the correct Units in place.  However, in the PDF TOC on the left nav,  the Unit 5 Lessons appear in Unit 4, the Unit 6 Lessons appear in Unit 5, Unit 6 has no Lessons, Unit 7 is correct.  I have spent a full day troubleshooting this.  Does anyone have an idea what the problem might be?
    Dec 9, 2013 12:03 AM   in reply to cassiel
    Strange things can happen thanks to the PDF setup > Bookmarks tab, though I suspect you have already checked that. I've occasionally shot myself in the foot by using two styles for level 2, for example, and not noticing that one of them had decided to sidle into the .pdf navigation as level 3 …
    Counsel of despair, if you have full Acrobat, would be to adjust the bookmarks manually so you can hand over the deliverable. Hope someone will come up with a more convincing answer, though!
