I downloaded the most current Window OS 8 (8.1) and afterwards I started having issues with my Flash Player working. It says that I need to install the latest version of Flash which I have done and it recognizes that it is already installed on my system if I try again.I have also gone through the steps to enable Flash object in settings and ActiveX filter, as directed. Neither of these solutions made a difference. I am running a 64-bit system. Can you help?
This is a known problem with Internet Exploder 11, which Microsoft has been aware of since October 18 when they released their latest "untested" browser. The pages can't recognize the browser, so they don't recognize any of the plugins, like Flash Player. So far, Microsoft has made NO indication that they have any plan to fix it soon.
Microsoft's recommendation is to use Compatibility View for affected pages, and "pretend" you're using an different browser. Trouble with that is it has seen limited success at best, and you have to individually enable it for EVERY page that has problems.
I'm not big on "pretending" so I recommend actually using another browser.
ANY of those will work where IE11 won't, with the Flash Player Plug-in (For all other browsers), and Chrome doesn't even need that because it has its own Flash Player plugin built in.
