Hello,
We have a sharepoint 2010 enviroment and recently upgraded our Acrobat X11 installs ( both reader/std/pro) to version 11.0.5.
We have a mixture of WIndows 7 32/64Bit IE 8 and IE 9 machines
After upgrading to 11.0.5 when users click a pdf file in a SP document libary one of two things happens depending if they have the
Adobe Reader Plugin Enabled or not
If the Adobe Reader Plugin is enabled, they will not get prompted to run/save the pdf file and it will not open in a new tab in the browser
If the Adobe Reader Plugin is disabled, they will get a popup window that has the correct URL to the PDF in the address bar but they will not be prompted to save or run the file.
If they click in the addrss bar and press enter the pdf will then load in the external reader/acrobat application.
This issue started with 11.0.5 updates, rolling people back to 11.0.4 fixes the issue.
I have attempted everything I can think of including rebuilding new machines with our image.
Has anyone see issues like this with the 11.0.5 update?
Investigating.
If a bug is confirmed, a fix may be delivered in the next release (can't promise). For a similar issue caused by a Microsoft bug, see http://forums.adobe.com/message/6106294#6106294.
Ben
Could you please share the exact behavior with 11.0.4 and 11.0.5.
Also please check if "Adobe Acrobat SharePoint OpenDocuments Component" enabled in your browser or not.
