LynSing717
Flex 4 display selected item from spark DropDownList
Dec 9, 2013 11:51 PM
Tags: #flash #flex #builder #arraycollection
Hi, I am newbie to Flex, I has a question to display the currently selected item from the DropDownList control(s) in the application. For example totalscreen that drop down with [1, 2, 3, 4] if 3 is selected then the only items in localscreen drop down will be [1, 2,3] and if the 2 is selected,for the nextworkscreen will only have 1 is display. I am using the dropdownlist and ArrayCollection.
enter image description here
private function updateLocal(event:IndexChangeEvent):void
               var aLocal:Array = [];
               var idx:uint;
               var length:uint = totalscreenSelect.selectedItem.data;
               for(idx=0; idx<length; idx++)
                       aLocal.push({data:"label"+idx});
i try to use Array and  using ArrayCollection too, however there are error also.
<s:DropDownList id="totalscreenSelect" dataProvider="{_dataProviders}" change="updateLocal(event);"/>
Any thoughts on if this is possible and if so how to implement it would really be appreciated.
Thanks in advance.
Using Flash Builder 4.7 with Apache Flex 4.11 sdk
