Hi All,
I'm new here and I have not had good luck searching the FAQs so, here I am. I have a new laptop with Windows 8. I just purchased Adobe Photoshop Elements 12 and Premier Elements 12 and installed them. My OS is x64 but the install didn't give me a choice. Now I notice that they are 32-bit versions installed. Simple question...Do they come in 640bit? If so, how do I get it? 64 bit can access more RAM so it would definitely be better.
Thanx
Cat
The tech specs for the programs explain howthey operate relative to 32/64...
http://www.adobe.com/products/photoshop-premiere-elements/tech-specs.html
Ned,
Thanx so much for pointing me in that direction. It definately says, " and in 64-bit or 32-bit mode on Windows 7 and Windows 8 & 8.1;" which means it should be able to run in 64- mode but I'm not sure how to make that happen. I work for a software company and our software has two different versions that are installed. So do you know if I have the wrong version or do they have some kind of switch that I missed setting on installation?
Thanx
Cat
Check if it got installed in both
The first would contain the 64-bit version.
