Drag Scrolling Textbox?
Dec 10, 2013 8:17 PM
Tags: #scrolling #drag #textbox #air_for_ios #air_for_android
I am looking for the AS3 code for a textbox that scrolls by dragging similar to that on an iPhone. I DO NOT want a scroll bar. I just want to be able to scroll through the text by dragging it up and down or side to side. I haven't found any complete code for this anywhere online so if someone can give me the complete AS3 code for this, that would be awesome! Thanks!
    Dec 11, 2013 5:33 AM   in reply to xp3tp85
    you can simply turn off the scrollPolicies of a textArea Component:
    //with a TextArea Component instance _ta on stage
    _ta.verticalScrollPolicy = "off";
    _ta.horizontalScrollPolicy = "off";
    this will hide the UIScrollbar and make the dragging you described available by clicking down inside the textarea and moving your mouse accordingly
  • kglad
    Jul 21, 2002
    Dec 26, 2013 7:01 AM   in reply to xp3tp85
    yes.
    right click your textfield>convert to symbol>movieclip.
    add a mousedown listener that adds and enterframe loop which calls a function that scrolls your textfield based on mouse position and add a stage mouseup listener to terminate the loop.
  • kglad
    Jul 21, 2002
    Mar 14, 2014 9:11 PM   in reply to xp3tp85
    var m,b:Number;
    paramF(10,0,tf.height-10,tf.maxScrollV);
    tf.addEventListener(MouseEvent.MOUSE_OVER,overF);
    tf.addEventListener(MouseEvent.MOUSE_OUT,outF);
    function overF(e:MouseEvent):void{
        this.addEventListener(Event.ENTER_FRAME,tfF);
    function outF(e:MouseEvent):void{
        this.removeEventListener(Event.ENTER_FRAME,tfF);
    function tfF(e:Event):void{
        tf.scrollV = Math.min(tf.maxScrollV,Math.max(0,Math.round(m*tf.mouseY+b)));
    function paramF(x1:Number,y1:Number,x2:Number,y2:Number):void{
        m = (y1-y2)/(x1-x2);
        b = y1-m*x1;
  • kglad
    Jul 21, 2002
    Mar 15, 2014 6:09 AM   in reply to xp3tp85
    here's code for that but you'll probably need to hire someone to implement it in your project.  i took the code from an ios project i made for a client last year/*
  • kglad
    Jul 21, 2002
    Mar 15, 2014 12:01 PM   in reply to xp3tp85
    no, you have to adapt that to your situation.
    in all cases, you'll need a mask for you movieclip and to use that code there are some paramenters you need to define and a tween class (i used tweenlite) to add.
  • kglad
    Jul 21, 2002
    Mar 15, 2014 3:12 PM   in reply to xp3tp85
    you're welcome.
