Serftosurf
Every time I start Illustrator CS6 I get an error message: "Error loading plugin AIHostAdapter.aip.
Dec 11, 2013 7:21 PM
"Error loading plugin AIHostAdapter.aip. I have tried reloading the program, updating, everything. I've checked the forums but no one seems to have a solution
    Dec 11, 2013 11:34 PM   in reply to Serftosurf
    Is it a 3rd Party plugin? Doesn't looks to be plugin included in AICS6?
    Dec 12, 2013 4:40 AM   in reply to Serftosurf
    It does not look like it is installed by default. I do not see it in my Extensions folder for CC and CS6.
    It could be that you installed an extension from a developer in the past. The AIHostAdapter.aip is mentioned in the Creative Suite Extension Builder Programmers guide.
    I would try to remove with the Extension Manager.
    Or otherwise use brute force and drag it out of the Extensions folder (you can always put it back if you are going to miss the error message).
    Dec 13, 2013 4:39 AM   in reply to Serftosurf
    Hi Serftosurf ,
    You can keep a copy of this plugin somewhere (for future use if any) and then try to launch Ai after removing this from the extensions folder. I hope this will help.
    Let us know if you encounter any issues after that or if it's resolved.
    Thanks!
