Espectador
HLS stops and no file under applications/livepkgr/streams/_definst_/mystreamname
Dec 12, 2013 4:38 AM
Tags: #iphone #hls #fms #stop #fme #no_files
Hi, I set up an audio only stream with FME to my FMS 4.5
This are the FME parameters:
envivo?adbe-live-event=envivo&adbe-audio-stream-name=envivo&adbe-audio -stream-src=envivo
FME conf xml
<?xml version="1.0" encoding="UTF-16"?>
          <filler>
                          <duration>50</duration>
                          <buffersize>6000</buffersize>
          </filler>
  <logs>
                           <enable>true</enable>
                          <path>c:\FME\</path>
          </logs>
          <mbrconfig>
                           <streamsynchronization>
<referencetime>
                                               <month>0</month>
                                               <year>0</year>
</referencetime>
                    </streamsynchronization>
          </mbrconfig>
          <rtmpconfig>
                    <rtmpbuffercontrol>
                              <maxrtmpbuffersize>512000</maxrtmpbuffersize>
                              <maxrtmpbufferlength>3600</maxrtmpbufferlength>
                    </rtmpbuffercontrol>
          </rtmpconfig>
</flashmedialiveencoder_config>
I am using iphone and jwplayer 6 in myiphone.
The streams run perfect and sundenly it stops and in the folder applications/livepkgr/streams/_definst_/envivo I have no files.
Then, if I stop and start the FME it starts again with no problem.
any idea?
Now I turn on my log in the FME.
thanks
