Juan-Manuel Herrera_TERRA
RED FRAME in source_Clip or Program_sequence of a media 720p MXF whit AFD(active format descriptor)
Dec 12, 2013 3:47 PM
Tags: #error #adobe #frame #playback #red #program #mxf #transcoding #source_clip #afd #active_format_descriptor
Hi Adobe,
As you can see here I have a file that I am not able to read in my new Adobe Premiere CC 7.2.0 as this red frame appear!
I hope you can help me whit my problem
I use Harmonics Rhozet to do and its seem like my filters add to my Watch folder may cause the problem as PP CC cant read the file.
In my transcoding setting I have insert AFD (Active Format Descriptor) processor 169_8 filter and a AFD TO SMPTE291m
Here is some capture of thoses filters:
Capture_Rhozet filter AFD Processor 169_8.JPGCapture_Rhozet filter AFD TO SMPTE291m.JPG
Here is the MEDIAINFO of my file:
Format                               : MXF
Commercial name                      : XDCAM HD 35
Format profile                       : OP-1a
Format settings                      : Closed / Complete
File size                            : 14.2 GiB
Duration                             : 53mn 41s
Overall bit rate                     : 38.0 Mbps
Encoded date                         : 2013-12-12 14:26:53.000
Writing application                  : Rhozet Carbon 1.00
Writing library                      : Rhozet Carbon 1.00
Video
Format                               : MPEG Video
Format version                       : Version 2
Format profile                       : Main@High
Format settings, BVOP                : Yes
Format settings, Matrix              : Custom
Format settings, GOP                 : M=3, N=12
Format_Settings_Wrapping             : Frame
Duration                             : 53mn 41s
Bit rate                             : 35.0 Mbps
Width                                : 1 280 pixels
Height                               : 720 pixels
Display aspect ratio                 : 16:9
Active Format Description            : Pillarbox 4:3 image
Frame rate                           : 59.940 fps
Color space                          : YUV
Chroma subsampling                   : 4:2:0
Bit depth                            : 8 bits
Scan type                            : Progressive
Compression mode                     : Lossy
Bits/(Pixel*Frame)                   : 0.634
Time code of first frame             : 00:00:00:00
Time code source                     : Group of pictures header
Stream size                          : 13.1 GiB (92%)
Audio #1
Format                               : PCM
Format settings, Endianness          : Little
Format_Settings_Wrapping             : Frame (AES)
Duration                             : 53mn 41s
Bit rate mode                        : Constant
Bit rate                             : 768 Kbps
Channel(s)                           : 1 channel
Sampling rate                        : 48.0 KHz
Bit depth                            : 16 bits
Stream size                          : 295 MiB (2%)
Audio #2
Format                               : PCM
Duration                             : 53mn 41s
Bit rate                             : 768 Kbps
Bit depth                            : 16 bits
Other
Type                                 : Time code
Format                               : MXF TC
Time code of first frame             : 00:00:00;00
Time code settings                   : Striped
I am waiting for a answer
Thank you
Juan
TerraTerra Communications Inc.
Message was edited by: Juan-Manuel Herrera_TERRA
